| How to fix stone guards Now fitting car with shiny bits post SVA. Any advice on how to fix the aluminium stone guards to the rear wings ? Car is still in gel coat and will be for a while yet until I can afford a spray job so it would be best to be able to remove the stone guards without damaging them when it comes to spray time. Cheers David |
| RE: How to fix stone guards David, I used 2 Dome headed (Hex Drive) stainless bolts (M4 I think) fixed with washers and nylocs - for the same reason as you. Rgds Jim |
| RE: How to fix stone guards yeah I used the same as above (from a company called Tifosi) Graham
| RE: How to fix stone guards Any chance of a photo of the finished item ? Did you put silkaflex around edge to prevent water and/or crap (technical term !) getting in between the stone guard and the fibre glass ?? Thanks David |
| RE: How to fix stone guards David, I'll see if I can take a snap later on (doing some research at the mo), no sealant used just Ali straight to Gel. Rgds Jim |
| RE: How to fix stone guards bit of blak wing piping (not to big) glue to back and wedged into place with the fitting of the actual guard. Will to pic tommorrow. Graham
| RE: How to fix stone guards David, Here goes x( The picture from the front shows the dome head at top right, the other 2 pictures are from behind, lower screw is self tapper, upper is another dome head onto nylock. HTH Jim (Oh, it worked! I must be getting the hang of this now |
| stone guards | Stu J | Wanted Adverts | 2 | 16-12-07 11:00 AM |
| Stone Guards - They do what it says on the tin | bogster | DAX Technical Questions | 2 | 08-07-07 08:35 PM |
| Stone guards. | philip600 | Pilgrim Sumo Technical Questions | 2 | 05-07-07 10:04 PM |
| Stone Guards | arowland | Pilgrim Sumo Technical Questions | 11 | 17-11-06 09:21 PM |
| stone guards | dave lambert | DAX Technical Questions | 11 | 05-01-06 04:15 PM |
