| Dax rear ride height Guys I am about to spend a bit of time on the rear suspension set-up of my Dax - majorly overdue The ride height at the rear is about 2cm different between the left and right sides (measured floor to chassis members), yet the ride height adjustment on the shock absorbers is set to a similar number of threads from the bottom - Hmmm. Clearly, I can drop one side a bit and raise the other using the adjusters on the shocks, but my gut feeling is that I have a problem elsewhere in the geometry. Should I be worried and climb under the back with a tape measure and start looking for some leftright inconsistencies, or is this normal and all due to the tolerances in the spring rates? BTW, the garage floor is flat and level. Any insight appreciated.... Many thanks |
| RE: Dax rear ride height That would make perfect sense! And my long-term memory is just returning now - can you not tell them apart because one has 9 turns and the other 10 or something like that? Some of you might remember that I had one collet slip over the top washer of one of the rear shocks shortly before SVA. (Incorrect collet in the box and I never checked - shame on me!). Anyway, the result was a bent spring which was replaced. I am sure that I checked the poundage at the time, but mistakes and screw-ups are my particular forte, so it's time to go back and check again... And I might just take that tape measure to the springs after all Many thanks |
| RE: Dax rear ride height Dave, are the springs identifiable? http://animatedgif.net/flags/-flags-uncat/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
__________________ Kev Davies South Wales Area Rep. DAX, 383 Chevy Stroker, |
| RE: Dax rear ride height Just taken mine off to send the Shocks off for reconditioning. The springs will either be marked with white paint on the top/bottom flat (or if your lucky stamped), or have nothing on at all {-} Cheers Jim |
| RE: Dax rear ride height Hi, mines the same, one side has a lot higher setting on the spring height than the other to get the same ride height. I dont recall every seeing or hearing that the springs were different ratings, but this would explain my settings. I also dont recall seeing differences on the springs when I fitted them, but have always felt the car handled oddly, thought I might need my corner weights setup. If theyre not marked how do you tell the difference? Phil
| RE: Dax rear ride height I agree, I don't remember every seeing anything about a mix of spring ratings at the back. To get and even height at the back the adjustment on mine is a bit different side to side. Can't say the car handles oddly though. Alex |
| RE: Dax rear ride height AK suggest 2 x 225 lbs each side on the rear, mine are adjusted to different settings to get the correct ride height from chassis. Don't forget the majority of the time, if your like me and the wife doesn't like open top motoring, the driver will be the only person in the car and it will settle more on the off-side, especially if your a fat g**. :tu :tu :tu :tu :tu :tu :tu :tu
__________________ Mike Cobraless I have a simple philosophy: Fill what's empty. Empty what's full. Scratch where it itches. HONDA ACCORD FOR SALE |
| RE: Dax rear ride height Mine has needed a lot more adjustment to the right rear than the left. I'd assumed 'cos of my lardy arse and my battery being in the rear right corner. but it's possible that the springs are mixed up. I didn't know there were two ratings. Hopefully Mr Brookes can tell us how to id them. http://animatedgif.net/flags/-flags-uncat/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Dax rear ride height Here's the low down. Some of the springs are marked on the flats at the ends in white or silver pen reading either 225 or 200. If you don't have these markings the only way to check without taking them off the car is to measure the thickness of the wire that they are made of or count the number of loops possibly, if you find that the wire is of different diamiters (I will have a check tomorrow...If i remember (A telephone call from one of you might help on 01782 577672.....Hint, hint) then all you need to do is to make sure you have one of each size on each side. If all the springs turn out to be the same rate then no problem. (Dax used to use the same rate on all 4 at one time and then altered the rate on 2 of them to improve the ride quality). Please bear in mind that you also have a steering column, pedal box and servo etc all hanging on the off side of your car so you will never get perfect corner weights at the back without completely screwing up the front and having that end of the car miles out. :tu
__________________ Pro Dax Builder Current builds:- Dax No.135---------Kirkham No. 2 Low Volume manufacturer LEMANS HARDTOPS FOR DAX AND PILGRIM |
| Ride Height | JonnyT | DAX Technical Questions | 14 | 22-11-07 02:50 PM |
| Ride Height for a GD Jag | ColinH | General Tech Tips & Questions | 3 | 16-11-06 07:26 PM |
| Ride height | Stu Kaynes | General Cobra Discussion | 2 | 07-04-03 07:59 AM |
| Ride Height | V8bassman | General Tech Tips & Questions | 3 | 04-04-03 09:08 AM |
| MKII Sumo Rear Wheel Ride Height/Arch Clearance | Mike H | Pilgrim Sumo Technical Questions | 7 | 28-02-03 05:51 PM |
