| Chevy 350 HO Gents, I'm considering buying a dax with a 350 HO chevy. How much horsepower does this have with Edelbrcok heads/holley carb? The guy reckons 400hp but that seems a bit ambitious to me. Also is there any way of guesstimating horsepower by acceleration times, say 60 to 100 mph. I suppose the real question is how do you know if something will do like it says on the can. If it is a standard 350 how much would it cost to get the power output up to 350/400 hp? Also is a T5 gearbox up to the job thanks Mike.B |
| RE: Chevy 350 HO I would think it'd be somewhere around 350-400 if it's got all the right kit on it. If it was a stroker like mine around 450.{-} {-} http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Chevy 350 HO Kev, The guy doesn't know that much about it as it wasn't his build. Just edelbrock heads and holley. Also, i have searched through old threads for help on rear diff identification. From that I can see I need to look on the rear housing to find a tag giving ratios. Will this also indicate whether its got limited slip or not. Mike |
| RE: Chevy 350 HO Hi Mike If you are lucky and the tabs are intact one tab gives ratio and another (if fitted) will say PL (powerlock) Regards Shane GD 351W |
| RE: Chevy 350 HO Mike Loads of people guess horsepower, and they're usually optimistic! My new 383 should be 450-500bhp, but I won't know until it's running and dyno'd. Torque is more important I'd say, but that's another story..... As to the diff. If it's limited slip, perhaps the easiest way to check it is to jack the complete back end up and turn one roadwheel...if the other one turns then it's a LSD, or jack up one side and try to turn the wheel. If it turns easily with the other one still on the road, then it's not, if it's hard to turn, it's limited slip. You're right about identification tags though, there should be one stating the ratio, and if it's limited slip, then a tag with PL should be on there too (PowrLok). If there are no tags, and you want to know the ratio, then you'd need to take the inspection cover off the back of the diff, and patiently turn the wheels as you count the teeth. The visual inspection would also give you the chance to see if it's a PowrLok or not. Just remember to drain the oil first! HTH Mat Current progress: Dax rediscovered under the dust, 383 Chev arrived from the USA, Tremec TKO in a box, and various bits on the shelf! |
| RE: Chevy 350 HO Hi Kev, What cam have you got in your 383? Does it have a lumpy idle? :OT David.
| RE: Chevy 350 HO Standard 350 is 250 hp I think. You need uprated cam, performance heads, carb etc. Depends how much you want to spend. Spanking new has cost me...erm. Well actually, I'm not sure. I guess around 6-7. That's good ol British skilled labour, no labouring around E bay trying to source parts. I just said, i want it to do what it says on the tin.. 60-100 times... about as long as it takes to say woo hooooo followed by a big laugh }( Have you seen a Dax? Does it have this engine in? etc etc etc. Welcome to the forum
__________________ Daytona 427.. Paul |
| RE: Chevy 350 HO Hi David, it's an Edelbrock Performer RPM #7102 cam. Actually it idles reasonably well at about 800 or less. It never used to until I replaced the faulty HEI dissy the engine came with. New HEI sorted it. http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Chevy 350 HO Thanks for that I will have a look out for it when I see the car. If I had one of those accelerometer gizmo's I should in theory be able to work out HP. Dave I seem to remember in a long ago thread you said you bought one. Did it work? Also Dave if you are wondering,I'm the one you phoned the other week regarding second hand cobs. cheers Mike |
| Chevy SB + TF-727 | lr88 racer | General Cobra Discussion | 5 | 22-06-05 06:05 PM |
| Chevy 350 | bitsilly | General Cobra Discussion | 6 | 15-06-05 12:01 PM |
| Chevy LS1/LS6 | chesterak | General Cobra Discussion | 5 | 28-09-03 10:22 PM |
| Oil for the Chevy | Frosty | General Tech Tips & Questions | 4 | 11-01-03 06:19 PM |
| Chevy what? | mikey | General Tech Tips & Questions | 4 | 07-11-02 09:26 PM |
