Old 22-03-04, 11:23 AM
Oil cooler
Do you fit the cooler before or after the filter? If there's a good reason for either way I can't see it - unless an engine failure and resultant filling of the cooler with debris is a good reason for having it after the filter.
Stan
:tu
Stan
Old 22-03-04, 11:35 AM
kdavies3's Avatar
RE: Oil cooler
Hi Stan,
you should fit the cooler after the filter, I assume you are going to use a thermostat to the system too.
You effectively want to have two possible circuits, a short circuit when the oil is cold through the filter and back to the engine.
A long circuit which is opened by the thermostat allowing the oil to flow from the filter, through the cooler before it goes back to the engine.
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 22-03-04, 07:14 PM
RE: Oil cooler
As per words above 2 x circuits, one hot one cold
Mike
Old 22-03-04, 09:43 PM
RE: Oil cooler
Kev/Mike,
Thanks for the replies....as the Yank Military - say HUA!!! (Heard And Understood - never could get why the letters are the wrong way round).
Stan
:tu
Stan
Oil cooler bogster DAX Technical Questions 8 10-04-06 02:40 PM
Is an oil cooler necessary? Andy302 General Cobra Discussion 11 28-06-05 11:12 AM
Oil Cooler Take Off SJ DAX Technical Questions 0 30-01-05 10:45 PM
HO 502 oil cooler Dezino General Tech Tips & Questions 0 29-01-05 06:43 PM
Oil Cooler mjculley General Cobra Discussion 2 25-06-03 09:40 AM
