Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    ian
    ian is offline Mechanic
    Join Date
    Mar 2002
    Location
    Reading, England.
    Posts
    285
    I'm confused : Chevy 350 ignition timing
    Hi folks, I think I need some help! I'm very confused.
    Last night I spent ages puzzling over the ignition timing on my Chevy engine. I am using a new dial-back timing light, complete with digital tacho and advance readout. Vac advance was disconnected throughout. At tickover (690 rpm) my timing mark is approx 40 degrees advanced - it's way off the timing tab. When I turned the dizzie to get the tdc mark to line up with the 10 degree timing mark on the tab the engine started to run really rough, revs dropped down to about 500 and it was obviously struggling. So I turned the dizzie back slowly to where the rpm was highest and the engine seemed most comfortable, again the timing appeared to be about 40 degrees advanced.
    Normally you would suspect the tdc mark on the damper. However when I rebuilt the engine I reset the tdc mark using a dial-guage on no.1 piston. Then I thought that the outer ring on my damper may have slipped (it is quite an old one.) So this morning I checked for tdc position using the positive stop technique, and guess what, my tdc mark is bang on.
    Other information : the dizzie is an HEI with MSD HEI kit ie hot coil, module. Also fitted Crane adjustable vac advance, although it was not connected. I am using the silver and blue springs for mechanical advance which were supplied with the Crane vac advance kit. The mechanical advance should start at 800rpm and be fully advanced at 2800rpm.
    Any suggestions would be most welcome. Thanks. Ian.
  2. #2
    ian
    Join Date
    Mar 2002
    Location
    Reading, England.
    Posts
    285
    RE: I'm confused : Chevy 350 ignition timing
    Just found the following on a US website :
    "Small block Chevy - These engines have used three different timing pointer locations. Pre '69 engines have the TDC mark 2 to the left of the keyway centerline. The '69 to '85 dampers have the TDC mark 10 to the left of the keyway centerline. The 1986 to 1991/1992 have the TDC mark 40 to the left of the timing mark. All of our SB Chevy dampers, as well as all other aftermarket dampers, use the 10 TDC position. Our 6.75" diameter models have two TDC marks, one that is 10 and one that is 40 to the left of the timing mark. If you have a pre '69 vehicle you can use one of the aftermarket bolt-on timing pointers to align correctly with the timing marks on our dampers."
    Looks like I may have the 1986 to 91/2 damper fitted to my engine which was made in 1981. This must mean that the TDC mark is NOT the mark to be used for timing. I think there may be another mark on there somewhere, I'll check. What a silly boy I am.....
    Cheers. Ian.
  3. #3
    simon's Avatar
    simon is offline Technical Director
    Join Date
    Feb 2007
    Location
    Essex, UK
    Posts
    3,463
    Ian, surely if the damper mark is set up to align with where TDC is, it doesn't matter where the pointer is, if the damper TDC mark is where the piston TDC is and it all lines up with the pointer then you're ok (or am I missing something here?)
    Simon
    WARNING: Translation of author's random thoughts may have resulted in the unintended introduction of grammatical errors, typos, technical inaccuracies, lies, propaganda, rhetoric, blasphemy, rambling, and/or exhibition of shocking levels of ignorance.
  4. #4
    ian
    Join Date
    Mar 2002
    Location
    Reading, England.
    Posts
    285
    Hello Simon. I don't think you're missing anything, I just think I'm going crazy. When I use the TDC mark on the damper as the timing mark with the timing light, it is showing about 40 degrees advanced at tickover. It should be about 10 degrees. But the timing in reality is obviously not that far out because that is where the engine is most comfortable, and it actually drives really well. The TDC mark is in the correct place on the damper ie when it lines up with the zero on the timing tab the no.1 piston is at TDC. I know this, I have checked and re-checked today. But what I understand from the website I saw earlier is that the timing mark is not the same as the TDC mark. It is 40 degrees 'behind' the TDC mark. If I can find this mark on my damper and use it instead I think I should be OK. Shouldn't I??
    Anybody else have any ideas?
    Ian
  5. #5
    Happy Jim is offline Technical Director
    Join Date
    May 2004
    Location
    Finchampstead, Berkshire, UK.
    Age
    48
    Posts
    2,563
    Ian,
    Are you clipping the light to no1 ignition lead or a.n.other ?
    Jim
  6. #6
    ian
    Join Date
    Mar 2002
    Location
    Reading, England.
    Posts
    285
    Hello Jim, definitely no. 1.....
    Ian
  7. #7
    markn is offline Chief Bottle Washer and Tea Boy
    Join Date
    May 2003
    Location
    Letchworth, Herts, UK
    Posts
    146
    Ian
    Assuming you've got the timing light on number 1 lead and are as you say at TDC with the 0 on the damper pointing at 0 on the timing plate you have a good starting point - there is nothing wrong. So long as you have measured TDC with a dial gauge or similar and noted a point on your damper and related that point with a position on your timing plate you can't go wrong.
    If it helps, I started mine first time the other day following a build up and it had 40 degrees initial, it ran OK because I had increased the idle speed really high and got more air in the engine. It ran better when at 16 (mine is high lift cam with overlap) but involved adjusting mixture and idle speed.
    If I were you, I'd set the timing where you think it should be, and adjust idle screw and mixture until things are right. Don't forget to check for air leaks and unplugged vacuum ports.
    Hope this helps
    Mark
  8. #8
    ian
    Join Date
    Mar 2002
    Location
    Reading, England.
    Posts
    285
    Thanks Mark, I'll have another go later. What concerns me is that the engine is obviously very unhappy when I set it to 10 btdc but seems fine at 40 btdc! I was wondering if I had got the distributor installed incorrectly by one tooth but I don't think it would make any difference, I'd just have to twist it more. For the record, no. 1 terminal on the dizzy cap is almost pointing dead ahead, maybe slightly towards the near side if anything. Thanks for your help, it is appreciated. Ian.
  9. #9
    kdavies3's Avatar
    kdavies3 is offline Driving God
    Join Date
    May 2004
    Location
    Cowbridge, United Kingdom
    Age
    56
    Posts
    7,955
    I assume you have your dial back timing light set up correctly?
    It sounds to me as already said that you may be one lead out and are timing on number two or something strange.
    That said I had some very strange readings on my original (new HEI) it was moving all over the place. I had to replace the HEI dissy for another new one, before I could get a steady reading.
    Kev Davies
    South Wales
    Kev Davies
    South Wales Area Rep. UKCC Membership Secretary
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE,TKO 600, Old School IVA'd and truly AWESOME
  10. #10
    Join Date
    May 2003
    Location
    Posts
    146
    I think you'll find you are 90% there. Most Chevy dizzys have no 1 at or about 11 o'clock. Just adjust it a bit at a time, a bit of timing - keep it idling, a bit of mixture adjustment - keep it idling - repeat the process and see how close you can get to your target 10 degrees.
    Sure as eggs are eggs - 40 degrees is too much
    Mark
  1. chevy 350 ci ignition timing
    By drrgriffiths in forum Pilgrim Sumo Technical Questions
    Last Post: 06-05-04, 12:47 PM
  2. chevy 350 ci ignition timing
    By drrgriffiths in forum General Tech Tips & Questions
    Last Post: 04-05-04, 07:25 PM
  3. Ignition timing for Chevy 350ci
    Last Post: 14-09-03, 08:41 PM
  4. Ignition Timing slippage on a Chevy
    By kdavies3 in forum General Tech Tips & Questions
    Last Post: 08-05-03, 08:05 AM
  5. Chevy ignition timing
    By millsd60 in forum General Cobra Discussion
    Last Post: 23-04-03, 10:59 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
