Old 17-04-04, 05:13 PM
Starting Trouble
Typical isn't it first big weekend out and the b"&&#% wont start reliably. :f :f :f It did run yesterday but more often than not doesn't crank fast enough to start.
While cranking the engine is turning over slowly which is sometimes accompanied with a clatter. x( I assume this is the solenoid or the drive gear not fully engaging
I've got 12.8 volts at the battery (which was on charge all last night) and 11.1v during cranking so I assume the battery is OK.
I've also got 0 ohms resistance between the body of the solenoid and the battery earth.
The engine spins freely without the plugs in and doesn't have the same clatter
Anyone any suggestions, I'm guessing there is a connection somewhere that doesn't like high current
Steve
Old 17-04-04, 05:52 PM
kdavies3's Avatar
RE: Starting Trouble
Steve, try using your jump leads to boost it a little.
It could be your battery has died over th winter it's not uncommon.
What engine do you have? If it's a Chevy you could try the remote solenoid mod much discussed.
Also check that your earth leads are all nicely clean and tight and not corroded at all. clean 'em and and vasilene 'em.
I had to jump mine last weekend after not being started for a month or so.
I took her to the Cotwolds over Easter and did a 200 mile trip.
It should be well charged now.:tu :tu
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 17-04-04, 06:20 PM
STEVE G's Avatar
I have to jump mine every so often,that way she dont mind me spending money on the Cobra.
Steve G {-}
GE427-Rover 281ci.(300+BHP)
Regards Steve G
Old 17-04-04, 06:46 PM
kdavies3's Avatar
I wondered if someone would come back with some comment or other.
Kev Davies
South Wales
Kev Davies
South Wales
Its allways the difficult ones to find
Its running awain now
Steve
Old 17-04-04, 08:37 PM
>'em.
>month or so.
>trip.
Hi Kev, are we talking about cars here or something else
>Kev Davies
>South Wales
Paul :tu
Daytona 427..
Paul
Old 17-04-04, 08:39 PM
Bugger, looks like Steve beat me to it...
Paul
Daytona 427..
Paul
Old 17-04-04, 09:05 PM
Exactly the same symptons. If it jump starts no problem then 99.5% it is the battery.
Mike
Old 17-04-04, 09:29 PM
i can recommend the optima red top batteries,if anyone is thinking of changing,they will sit happily for months at a time and show no signs of losing charge,bit expensive though! :tu
gd jag,ford 302,tremec tr3550
Old 18-04-04, 01:00 AM
If the battery voltage is 11.1 when cranking, there's naff all wrong with the battery.
The sort of poor connections we may be dealing with here won't show up on a standard multimeter. A tenth of an ohm is WAY too much!
Best bet is to measure on volts under load (ie when cranking).
You may need an assistant.
Test 1) Meter neg lead to battery neg. Meter pos lead to starter motor casing.
Test 2) Meter pos lead to battery pos. Meter neg lead to starter main pos terminal.
Test 3) Meter pos to solenoid wire (white/red?). Meter neg to starter casing.
Tests 1 and 2 should register zero volts when NOT cranking, less than 1 volt when cranking.
If exceeding 1 Volt, trace back along the circuit path looking for poor (loose or corroded) connections. Perform the voltage test to intermediate points (eg earth cables bolted to chassis and engine) to narrow down the fault if everything LOOKS ok.
Hint: Poor connections will get HOT with this sort of current passing through them.
Test 3 should register 8 volts absolute minimum. If your battery is 11V, I'd expect at least 9.5 volts.
If those tests all pass OK, it's summat mechanical. BUT it definitely sounds like the solenoid de-energising due to low voltage, then energising again beause the motor load has been removed.
Simon.
Internet trouble dave The Cockpit 3 29-10-06 01:34 AM
Tin top trouble! JonnyT General Tech Tips & Questions 10 24-04-06 05:17 PM
Head trouble? MacGD016 Engine Tech Tips & Questions 5 10-08-05 06:38 PM
Holley trouble fab168 Newbies 3 29-03-05 06:41 PM
RV8 Trouble Will General Tech Tips & Questions 2 23-12-02 09:28 AM
