| Rev Counter Can anyone throw light on to this, for some reason my rev counter will drop to zero and after a few seconds work correctly again. I have just checked for loose wires but there does not seem to be any. Car runs fine just the rev counter hates me :} Thanks Paul |
| RE: Rev Counter Paul, Is this a new build, or something that's been running OK for a while and now it's not? Please post info on make/model of tach and type of ignition - points, electronic, MSD etc. Also whether loss of indication is random, or at certain rpm, or under acceleration/deceleration etc. Simon.
| RE: Rev Counter thanks for your swift reply, this is not a new build it is a sumo mark 2 with rover 4.6 i will have to go up the garage to get the make of the clock but what i know at the moment is, loss of indication is random i notice it more at about 1500 rpm and under then it just drops then comes back again. under light acceleration distributor is Lucas 'Limb' system 35DLM8 Thanks Paul |
| RE: Rev Counter Paul, I'm guessing this is a "voltage operated" tach. If it was a "current operated" tach, loose wiring connections would affect the power supply to the ignition and cause a misfire. Do you have access to a multimeter? If you have, try these tests: 1. Power to tach: Connect multimeter on volts DC between tach + supply and tach earth. Have an assistant watch the meter as you go for a drive. See whether the supply is lost when the indication is lost. 2. RPM signal from ignition: Connect multimeter on volts AC between the tach input and tach earth. Have an assistant watch the meter as you go for a drive. See whether the voltage is lost when the indication is lost. The usual culprit on tach failures (if it's definitely nothing external) is a capacitor either failing or becoming dry-jointed on the circuit board inside the tach. Simon.
| RE: Rev Counter i just love this web site it is full of information, i will try that tommorow simon, thanks :tu paul |
| rev counter | Clarkson | General Cobra Discussion | 7 | 26-04-06 03:55 AM |
| Rev Counter | malbrook | Pilgrim Sumo Technical Questions | 3 | 25-04-05 12:39 PM |
| V12 Rev Counter | Chris_Mann | General Tech Tips & Questions | 1 | 01-02-05 06:18 PM |
| Rev counter | Daz B | General Tech Tips & Questions | 4 | 07-10-03 04:47 PM |
| Hit Counter | choogh | The Cockpit | 5 | 05-09-02 11:26 AM |
