| Triple plate clutch set-up I have just fitted an AP racing triple plate clutch. Set-up seems OK & everything appears correct but I cannot rotate the gearbox with clutch disengaged & gearbox in gear. Looking through the inspection cover in the bell housing I can see the correct & full movement is being achieved & the friction plates do appear to release. Am I missing something obvious? Am I expecting too much without the motor running? Anyone got any experience of triple plate clutches that can offer advice? Baldric
__________________ Baldric |
| RE: Triple plate clutch set-up Ok, sorted. One friction plate installed reversed=clutch that will not disengage. Doh! Baldric
| RE: Triple plate clutch set-up Steve, Yes motor is RV8 (5.2 supercharged + Nos) Clutch is AP Racing CP7373-CE90-SF With gear plates. Hub is CP2822-23-FM3 & sliders are CP2822-31-FM3 all good for around 850Ib/ft. Used with AP racing hydraulic clutch release. Gearbox is CTS built Tremec T5 with quaiffe gears semi-helical wide ratio racing unit good for about 650Ib/ft (probably more in my light weight Cobra). See picture of clutch attached. Baldric
| RE: Triple plate clutch set-up Steve, PM is done Baldric
| new plate | claude3c | General Cobra Discussion | 3 | 17-06-07 03:55 PM |
| clutch friction plate for getrag box | zerocool | The Loan Forum | 8 | 20-04-07 08:45 PM |
| Triple wipers | Karl | General Tech Tips & Questions | 6 | 05-01-04 02:00 PM |
| Clutch plate orientation | dave | General Tech Tips & Questions | 6 | 07-11-02 09:24 PM |
| Clutch Plate Alignment | choogh | General Tech Tips & Questions | 9 | 03-07-02 11:04 PM |
