| RE: No oil temp sender take off on EDA engine? >Which as I said is in the sump, the oil is pumped from the >sump through the cooler and back into the oil gallery, through >the engine and drains back into the sump. Oil flows through the cooler first, then down into the sump, the oil pump does not pick up oil from the sump and then through the cooler. It is a sandwich plate between the filter head and filter bowl.
| RE: No oil temp sender take off on EDA engine? Robert, that engine was running a massive test bed oil cooler. The flow diagram would go as follows: Oil is sucked up from the sump via the oil pickup pipe, through the the pump and filter. 1. "Engine cold" it will go through the engine oil galleries and drain back to the sump. 2. "Engine Hot" the same but may divert through the cooler if the thermostat has opened supplying cooled oil back to the gallery, then the hot worked oil will drain back through the block into the sump (not via the cooler). Therefore the hottest oil will be in the sump at the extremes of it's useage. :tu :tu http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: No oil temp sender take off on EDA engine? I thought it went from the engine to oil cooler then to sump, still, I could be wrong, very wrong, wouldn't be the first time.... :-; :-;
| RE: No oil temp sender take off on EDA engine? I think me and the rest of automotive development community have got it right over the last hundred years or so. :tu :tu :tu There again I know naff all about websites and all that stuff. So I bow to your knowledge and experience in your field. :tu :tu :tu http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: No oil temp sender take off on EDA engine? So, educate me, I always like to learn stuff. The oil flows from the sump, through the pump, through the oil cooler (if there is one and the waxstat is open) up into the galley, down the oil drains and back into the sump. Is that right?
| RE: No oil temp sender take off on EDA engine? That's about it, the work is done as the oil is squeezed through the bearings on the crank etc, chain tensioners and tappets etc. providing lubrication and cooling. When it comes out of the bearings etc. it will will drain back through the cast oil drains in the heads and block, picking up more heat on it's way back to the sump. :tu :tu :tu :tu :tu http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: No oil temp sender take off on EDA engine? Jeeez Rob, this is Nuursery school stuff.. Keep up! :} Paul
__________________ Daytona 427.. Paul |
| RE: No oil temp sender take off on EDA engine? What if there is a leak? Where does the oil go then (other than on the floor(for an external leak)? {-} Rob :tu
__________________ Cobra-less |
| RE: No oil temp sender take off on EDA engine? Is the gallery plug a freeze plug beacuse mine wont budge:f |
| How have you plumbed your oil temp sender? | Andy302 | General Tech Tips & Questions | 4 | 18-06-06 07:40 AM |
| Water temp sender | JonnyT | General Tech Tips & Questions | 12 | 02-05-06 03:28 PM |
| oil temp sender | macdonaldm | Engine Tech Tips & Questions | 4 | 09-05-04 05:14 PM |
| Oil Temp sender | Ian D c | General Tech Tips & Questions | 0 | 24-04-04 09:57 PM |
| water temp sender | simon | General Tech Tips & Questions | 5 | 22-08-02 12:10 AM |
