| RE: Chevy won't start Hi Warren. From your latest post I would conclude that your problem was due to the ignition timing being too far out. But you thought you had set it correctly at 8 degrees BTDC. Is the harmonic damper the one originally fitted to your engine? Or is it a new/replacement one? As you may know GM had these made with the timing marks in three different positions relative to the keyway. On mine I had to measure TDC on piston 1 with a dial guage and make a new mark on the damper because of this. If you are looking at a 'false' TDC mark on the damper you could get the situation you describe. Hope that helps. Ian |
| Where do I start | AndyInSpain | General Cobra Discussion | 0 | 21-08-07 04:02 PM |
| Can I start her up?? | salypenter | General Tech Tips & Questions | 30 | 06-07-07 06:14 PM |
| Just before I start her up..... | qkingston | General Tech Tips & Questions | 10 | 23-06-07 05:01 PM |
| First Start up Almost !! | cliffords | Engine Tech Tips & Questions | 20 | 20-05-07 05:28 PM |
| Now it won't START | MacGD016 | Engine Tech Tips & Questions | 26 | 05-10-04 11:30 AM |
