| Which brake discs? Ok, Building up the parts list for an order. Which brake discs are recommended for the front and rears? Car will be used on the road, may go on the track nce in its lifetime if Im lucky!! Ford 302 with RPM package. Do I need drilled and grooved or will just vented do? Or do I put grooved on the front and vented on the rear? Also any advice on value for money suppliers? Any help welcome! Got to go and stand in a field looking at trees, shrubs and plants today! Oh Joy! Cheers Andy House filling up with bits, 1971 302 and Jag rear axle waiting for rebuild, wife not so amused!
__________________ Andy Ford 302 336 BHP 331 ft/lb's , GD JAG249 rolling!! Maybe engine start this year, thats 2010!!! www.andysgd427.blogspot.com |
| RE: Which brake discs? Hi Andy, bog standard XJS discs will do the job very well even on the occasional track day. You could use EBC Green Stuff pads as a bonus but not really necessary. The point is that the standard brakes were designed to stop a two ton Jaguar from 150 mph. So a Cobra weighing only half of that is easy for them, don't waste your money on the fancy drilled vents etc, they may look cool but are unecessary and you'll stuggle to get them warm on cold days. This very advise was given to me by a fully qualified brakes development guy that I know. http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
__________________ Kev Davies South Wales Area Rep. DAX, 383 Chevy Stroker, |
| RE: Which brake discs? Kev, thanks for that, so just the bog standard replacement ones listed in Wards catalogue then. Sounds good! Cheers Andy House filling up with bits, 1971 302 and Jag rear axle waiting for rebuild, wife not so amused!
| RE: Which brake discs? Fair comment Russ, as the prices aren't much different, I know what you mean about the brake dust it's a bast**d to clean off. http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Which brake discs? Andy, good luck with the build. I used standard 4 pot Jag front and standard rear set up for several years without any issue. Then I changed to cross drilled front with EBC green pads on the front and there is an improvement as Russ notes below.
__________________ Regards Nigel B Unique Autocraft Python Chevy 350 ZZ4 TR3550 Ex GB, DE, JP, GB now back in DE once again!! |
| RE: Which brake discs? Right, Ill look those up! Thanks! Andy House filling up with bits, 1971 302 and Jag rear axle waiting for rebuild, wife not so amused!
| Drilling/grooving brake discs | Robin427 | General Tech Tips & Questions | 13 | 30-03-09 03:55 PM |
| Brake discs | malcolmbuck | Pilgrim Sumo Technical Questions | 10 | 10-01-07 05:11 PM |
| Discs........... | h8jse | General Cobra Discussion | 5 | 02-01-06 09:37 PM |
| Brake discs | CycleSi | General Cobra Discussion | 2 | 10-11-05 03:10 PM |
| 2nd attempt Brake at which brake discs!! | Andy302 | General Cobra Discussion | 1 | 08-05-04 07:31 PM |
