Old 18-04-04, 11:20 AM
Steering rack set up
Hi Guys,
Have just bolted the steering rack in position and fitted the track rod ends and even when they are fully wound on I cannot get the discs to parallel or slightly toe-in as suggested.
The build instructions states that the GDJag installation might require the rack ends to be shortened by a 1mm or so but this won't help to solve my problem as I've run out of thread on the steering rack.
Any advice please??
Best regards,
Richard Dear
GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!!
Old 18-04-04, 03:33 PM
RE: Steering rack set up
perhaps the rack arms have been fully wound in at the rack end?
you can loosen off the gaiter and check this
gd jag,ford 302,tremec tr3550
Old 16-05-04, 05:35 PM
davidcot's Avatar
Hi
I had the same problem. The rack had to be replaced as the rack arms where to long. Andy replaced the rack after it was confirmed at fault.
David
GD427Mk3 Chevy 350CI On the road May 2008
Old 16-05-04, 08:17 PM
I had the same problem, ie the track rod ends screw on up to the end of the thread on the rack and still not enough toe in.
My solution was to grind off about 5mm from each track rod end, enabling them to screw on another 5mm each..
Problem sorted..
Adrian
There ain't no replacement for displacement..
Costs to date: [font color=red]£7075.57[/font]
Pain in Wallet: Moderate
Progress: [b]Chassis rolling, pipework fitted, waiting for the engine..[b]
What Steering rack? donut Pilgrim Sumo Technical Questions 5 11-01-08 05:42 PM
Which steering rack ? Toddy DAX Technical Questions 4 09-10-07 05:47 PM
dax steering rack? shiney General Cobra Discussion 4 14-05-06 07:45 PM
Steering rack set up richardd General Tech Tips & Questions 14 15-06-04 03:08 PM
Steering Rack BAZ General Tech Tips & Questions 3 10-03-03 10:13 AM
