Old 04-06-04, 07:27 PM
Fan Not Working... Help!!
The radiator fan has stopped working. I checked the relay fuse and it seems OK. If I short across the thermostatic switch in the radiator it fires up OK so am I correct in assuming the thermo switch is buggered? Is there any other way of checking this?
It's the sort that is screwed into the rad so is it a simple replacement from a motor factors. Is there a paticular type. Presumably I have the drain the water out again too.
Please reply soon - I'm planning to go to Rockingham but won't be able to without the fan working
Kevin......
Old 04-06-04, 07:53 PM
Club Sec/Rep Liason
Re: Fan Not Working... Help!!
Hi Kevin.
If you short out the switch and it works its almost certainly shot. There are different temp ranges, normally marked on the flats, or the casing of the switch. Ie 92c-82c, 100c-92c.
If its either of these I have some your welcome to have. I,m only in Barcombe just south of Uckfield, In fact I'm also going to Jarvis Brook in the morning for MOT, so I could drop round. Failing that a trip to Martin Story in the morning is in order. Mail me if you want either of mine.
AK 427 351C T5wc
Old 04-06-04, 08:02 PM
Chris,
many thanks - just sent you a mail.....
kevin.....
Rev Counter Not Working markr Pilgrim Sumo Technical Questions 6 22-10-07 07:09 PM
Is this working for you guys? robert General Cobra Discussion 10 28-05-07 10:04 AM
Speedometer Not Working bogster General Tech Tips & Questions 38 06-05-07 07:37 PM
PM's aren't working for me. kayjayd Feedback, Membership and Help 4 15-07-06 09:56 AM
Working with GRP mylesdw General Cobra Discussion 1 15-12-04 08:56 AM
