| Edelbrock mixture screws I have a ford 302 with an Edelbrock Performer Carb. My problem is that when the engine is hot especially in warm weather when travelling slowly on constant light load (below 1500 revs) the engine does not run smoothly. Would adjusting the carbs help. Any advise would be greatfully recieved. Thanks guys. |
| Re: Edelbrock mixture screws It might help if your current settings are incorrect. Take a look at the Edelbrock web site it may tell you what you need to know. http://www.edelbrock.com/automotive/eps_intro.html
| Re: Edelbrock mixture screws Well In The Manual It Say,s "anticlockwise IT MakeS It Rich And Clockwise Makes It Lean, But I Have A Felling Its The Otheway Around ? Not Sure |
| Re: Edelbrock mixture screws I recently installed the Weber package on my engine and found exactly the same problem. This was cured by installing a 1 inch spacer that it also as acts a heat barrier, purchased from DJ Ellis for around £35. This has transformed the engine response at low revs. Paul |
| Re: Edelbrock mixture screws Stu For info the 1" phenolic spacer is cheaper from Real Steel :thumb:
__________________ Keith :-} Ignition upgraded and back on the road again |
| Re: Edelbrock mixture screws Wilf No I do not have a vacuum advance unit on distributer. But the good news is that engibe is running much better now that I am buying fuel from Tesco (was buying from BP). |
| Re: Edelbrock mixture screws Good. BTW, screw them in to lean it, out to richen. Tesco fuel not normally known as the best in the world. For "normal" (i.e. not Optimax etc.) fuel, Texaco seems good. But if Tesco petrol works for you, stick with it.
| Re: Edelbrock mixture screws Can I use this thread to ask a daft question please? What is the difference between a Weber 500 and an Edelbock Performer? Are Edelbrocks actually manufactured by Weber? David Large
__________________ David Large Bald Surfer with a BRA 289 |
| Holley Idle Screws | Russ-Notts | Engine Tech Tips & Questions | 1 | 06-10-07 02:45 PM |
| rich mixture | craigh | General Tech Tips & Questions | 10 | 09-08-05 07:34 PM |
| Setting the Mixture | mr bidd | Engine Tech Tips & Questions | 2 | 09-07-05 07:15 AM |
| Allen screws | Keith S | General Tech Tips & Questions | 6 | 07-07-05 12:44 PM |
| Screws or bolts size | Cobra289 | General Tech Tips & Questions | 8 | 07-02-03 11:45 PM |
