Old 16-07-04, 06:44 PM
Andy302's Avatar
Re-using Jag nuts & bolts.
Your opinions on the following greatly welcomed......
Do you think that it is safe to reuse most of the bolts etc from my jag bits, obviously bolts etc with signs of damage will be replaced but most have just head rust with clean threads. Some have slight rust to threads (not sure what to do with those) I had thought about doing the following.
1) Degrease.
2) Maybe get the heads lightly blasted to remove surface rust. (or use a wire brush!)
3) Degrease again with POR15 Marine clean.
4) Submerge in POR15 metal ready (eats rust and coats with zinc phoshate.
5) Oil and store.
6 )Reuse.
What do you all think.
Also do I need the upper wishbone rubber bump stops on a GD?
Andy
www.andysgd427.blogspot.com
Old 16-07-04, 07:10 PM
rich's Avatar
Re: Re-using Jag nuts & bolts.
Andy,
buy all new nuts, Places such as WARDS sell them all, and to the overall cost its not worth the worry when your doing 70mph+, whether those old reused nuts are going to stay tight.
Rich
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
Old 16-07-04, 10:13 PM
>>Also do I need the upper wishbone rubber bump stops on a GD?<<
The simple answer is 'no'
Pete
Pete
GD Jag, 350 Chevy, Tremec TKO
Old 17-07-04, 06:34 AM
Andy302's Avatar
Thanks for the replies, new nuts and bolts it is then, rubber bump stops in the bin!
Andy
Old 17-07-04, 07:42 AM
rich's Avatar
andy,
bolts are a lot tougher than nuts, and unless they are in bad shape you should be ok to re-use them. Things like caliper bolts should be fine to reuse.
Rich
rich.
Old 17-07-04, 07:58 AM
Andy302's Avatar
Rich,
Yeah, thinking again on the subject I realised that if I pitched up at my local dealer with an old jag and asked then to change my discs or calipers etc they would just reuse the old bolts, Im goiing to price up for new ones anyway and see what the price difference is. New disc bolts and washers weigh in at £22.
What did you think to my reconditioning plan for the bolts, using POR15 metal ready etc?
Thanks for your help.
Andy
Old 17-07-04, 07:09 PM
STEVE G's Avatar
I replated and de-embrittled all the special bolts(dif mounting and caliper bolts) on my axle all the rest I replaced with stainless.
Regards Steve G
Jag Suspension + stainless steel nuts & Bolts martin_t General Tech Tips & Questions 7 06-01-07 05:54 PM
Nuts and bolts again cliffords General Tech Tips & Questions 0 30-12-05 03:16 PM
Nuts bolts and paint cliffords General Tech Tips & Questions 8 07-12-05 08:45 PM
Am I missing some nuts and bolts? duncanh Pilgrim Sumo Technical Questions 3 01-12-03 07:00 PM
Am I missing some nuts and bolts? duncanh Snake Watch & Industry News 3 30-11-03 02:47 PM
