| Fuel Pump Problem I have a problem fitting the mechanical fuel pump to the 350 Engine.. Well, actually 2 problems...!!!! I have also included a few pics to try explain also... 1) In the engine, there is a space for the mech fuel pump, sort of shaped like the end of a terraced house... In the centre of this is a maybe 10mm rod, which I understand bobs in and out and makes the attached fuel pump, actually pump, doing this by pressing an arm on the fuel pump... Well, on my fuel pump, the arm that does the pumping would appear to protrude out of the pump by maybe 1.5" or so.... and when I press that arm in as far as possible, the arm is protruding out of the pump by say abou 1".... The rod part of the engine that makes the pump work, is almost flush with the mating face of the fuel pump hole... So I cannot get the fuel pump any closer to the engine than about 1.5".... 2) The fuel pump, even if it were to fit easily into the engine hole would be way too close to the brake pipes and chassis member to be comfortable. It probably will not even fit at all..!!! Anyone with an AK any suggestions for me???
__________________ -------------------------------------- AK427, -------------------------------------- |
| Re: Fuel Pump Problem Goldie Chuck it in the bin, buy a blanking plate for the hole and buy a Carter Electric fuel pump from Real Steel.
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Re: Fuel Pump Problem oh dear, I did not want to hear that really, quite fancy having a mechanincal pump. Surely someone has built an AK with a mechanical pump???
| Re: Fuel Pump Problem Goldie I didn't attempt to fit one as Ken said they where very tight on the chassis rail, the Carter I have is fitted to the side of the gearbox, you can't hear it and it copes with 355 Chevy and Holley 750 vac secondary without any problem. :thumb: :thumb: and reasonably priced at about £50 :thumb: :thumb:
| Re: Fuel Pump Problem Goldie, I know I asked this question before and I got some positive feedback. I therefor ordered a Holley machanical that arrived the day before I had to leave for France. I am now back home and I should know by tomorrow if it fit or not. My AK is left hand drive so I don't have to worry about the break pipes but I still have to stay clared from the chassis member! Ps. I would hate it, if it turns out that my father was right when he told me to go for an electrical fuel pump!
__________________ When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there\'s no end to what you can\'t do! |
| Re: Fuel Pump Problem cool, i wait with baited breath..!!!
| Re: Fuel Pump Problem I used an inertia switch with the electric pump, any bangs or crashes and it cuts the pump, be super safe and use with Wilfs preassure switch cut off. :thumb:
__________________ Gary Custom Exhausts & Headers Little boys wear Bowties, Flatheads are for nerds, Get real get Mopar ww.sidepipes.co.uk |
| Re: Fuel Pump Problem Get a holly oil pressure fuel switch, easy to fit, also has a supply from the solenoid so pump starts straight away, then the oil pressure takes over and keeps the contacts closed. Oil pressure drops cuts out the electric pump. All thats required is a "T" with your oil pressure guage plumbed in as well. Regards Steve Hi Wilf how the devil are you?
__________________ Steve Richards LS1..........so smooth.........so economical! Growing old is inevitable - Growing up is an option |
| Re: Fuel Pump Problem Enough about electrical and back to the mechanical ones... I mounted my Holly (polished aluminium one from Summit) today and it fitted perfectly. I forgot the digital camera but ~ 10mm from the engine mount and ~20mm above the chassis member. That was the only thing that worked out in the garage today...
| Problem with oil pump stripped thread | BenBaron | General Tech Tips & Questions | 1 | 18-06-06 03:32 AM |
| Fuel pump problem? | Mr Bling | General Tech Tips & Questions | 7 | 11-04-06 09:48 PM |
| fuel pump | lordy | Pilgrim Sumo Technical Questions | 13 | 12-08-05 11:06 AM |
| new fuel pump | MARTIN123 | General Tech Tips & Questions | 1 | 21-01-05 04:10 PM |
| Fuel Injection fuel pump problem. | Poohbear | Engine Tech Tips & Questions | 20 | 11-05-04 10:53 AM |
