Colin,
Where in Telford are you? (P.M. me for security if you wish), I'll pop around and take a look.
Afternoon all
Anyone got any sure-fire/more accurate method of transferring the centre point of the gearstick from the chassis to the body in order to cut the hole out. I've tried several ways using the tunnel mounting holes as reference, but no surprise, failed to hit the same point twice - not out by much, but enough not to want to drill (yet). Unfortunately the two top tunnel mount points (which would have been ideal due their proximity to the gearstick) haven't been drilled in the body.
Thanks
Colin
Colin,
Mark Smith
I managed to use the lower mounts as guides by marking out some pencil lines with the spirit level on the tunnel area sides and top,and then measuring from these to mark out the required hole,I think it was more luck then judgement but it was spot on
gd jag,ford 302,tremec tr3550
Ditto,
I measured plumb down to the lower rear body mount holes, then along to the gearstick. I transferred these measurements on both sides to the body and marked it up. As a double check i did the same to the front upper tunnel bolts and measured back to the gearstick.
All worked out fine front to rear, but i forgot the stick is slightly to the drivers side of centre. Drilled the hole undersize though, so i can open it out to the correct position.
Mark
he lives around the corner from you....... you could walk
Steve
DAX 383 ci SBC 440hp...SOLD
GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
Project Tango "Old School" GD, 440 hp LS3 ....SOLD
460 HP LS Griff now OTR...roll on summer
I measured from the gearstick along the top of the chassis top plate where the body would sit.
I then transferred that measurement to the body, allowing for the bulkhead thickness of 10mm
Make the hole as small as possible, (40mm) and enlarge when the body is in place. a dremel will make enlarging the hole a 5 min job.
I found the forward and rear "throw" of the gearstick may mean that a hole cut equidistant around neutral position is not be the best (the hole in my tunnel is slightly offset to accomodate the throws on my 6 speed plus reverse
when you're ready to put the body on drop me a email if you need a hand, I don't live far (Much Wenlock). my email is sgullick@medigas.co.uk
Steve
Steve
I don't believe it-right in my back yard! From Colin's house I can see mine, only four houses away as the crow flies.Originally Posted by Steve
These seems to be quite a handfull of Cobras in the Shropshire and surrounding area. I was discussing with Colin starting an Area Club. Who have we got?
Mark Smith
Mark
I didnt want to give colins location publically, but I was chatting with another cob friend a couple days back who had met colin.
There's you (dax), Colin(gd), Me (gd), Stu Kaynes in ironbridge
(GD), Paul in market drayton (GD).
I was talking to Stuart about getting out Sunday coming, perhaps we can get together somewhere for a beer
Steve
Steve
..and there is an AK near Crudginton; I was going to see him last night with Colin, but too short notice for me. A get together sounds great. Unfortunately I am out of the country Wednesday until Monday, so I can't make this Sunday.Originally Posted by Steve
Mark Smith
I`m interested , especially if the weather is fine. (no roof yet!!)
Paul
Bookmarks
