| Re: Flywheel & bellhousing query I'm not sure how it should be done, but i can tell you how i did it. I checked mine with the flywheel off, just because i didnt have a flywheel that fitted at the time. The flywheel will be a snug fit, but should go on with a few well aimed taps. If you're using a lump hammer you may have a problem. Remember to fit the crank bearing before you bolt the flywheel on, remember to fit it the right way around, as you're never getting it out again.! step 1: attach the bellhousing to the engine. (no gearbox at this stage) step 2: attach the run out gauge to the crank. I used a couple of bits of angle iron bolted to the crank rather than the magnetic type. Make sure its FIRM and cant wobble!!!! step 3 position the gauge on the inner or outer face, as per my pictures on thread Adjustable RV8 Rockers and spin the crank through 360 degrees. If you're lucky the dial will not change more than 5 thou (.12 mm) This would prove the bellhousing is parallel with the engine Step 4: Point the dial at the edge of the bellhousing opening and spin the crank 360 degrees. Again if the dial never moves more than 5 thou you're in business as this shows the centre of the crank is also the centre of the hole. step 5: take the bellhousing off, bolt the flywheel on, bolt the clutch on, being careful to line the plate up, and you're away. Of course if the thing doesn't line up you'll need to consider shims and offset dowels
| Re: Flywheel & bellhousing query Hi Davidcot, Use a soft faced or heavy rubber mallet to get it started, but don't hit it on the plate surface. As you tighten the flywheel bolts in a star fashion they will pull it on flush. Maybe this will help. http://www.cobraclub.com/html/cobra_28.shtml http://www.novak-adapt.com/knowledge/clutches_etc.htm Regards Chris |
| Re: Flywheel & bellhousing query Hi Again, I forgot to mention use a clutch alignment tool when fitting the friction plate, otherwise all your effort aligning the bellhousing will be wasted as you won't be able to get the gearbox input shaft in properly. Most decent clutch kits come with one. Good luck. Chris |
| Re: Flywheel & bellhousing query David, as far as I'm aware the Repower bell-housing does not require "dialing In" that's why so many people go for them. May be wrong but I'm sure I've read that on numerous occasions. |
| Aluminium bellhousing Hello, I have an aluminium toploader and I was wondering if there are aluminium bellhousing ; in USA, Kee makes the aluminium case transmission but he does not make similar bellhousing. Have nice Holidays |
| Re: Flywheel & bellhousing query Quote:
__________________ Pro Dax Builder Current builds:- Dax No.123---------Kirkham No. 1 |
| Rv8 Flywheel | oldcobber | Engine Tech Tips & Questions | 7 | 22-01-07 04:09 PM |
| Flywheel | gareth08 | General Cobra Discussion | 4 | 16-10-05 08:33 AM |
| Starter, Flywheel and Bellhousing? | garyholden | General Tech Tips & Questions | 4 | 27-05-05 02:33 PM |
| Flywheel | Goldie | General Cobra Discussion | 4 | 25-04-05 11:38 AM |
| Flywheel anyone? | Iain | General Cobra Discussion | 12 | 24-01-05 06:39 AM |
