Results 1 to 3 of 3
  1. #1
    Andy302's Avatar
    Andy302 is offline Chief Engineer
    Join Date
    Apr 2004
    Location
    Swindon, Wiltshire, England.
    Posts
    1,821
    Ford bearing numbers decode...
    Can anyone decode the numbers on these Ford bearings?
    Rod bearing : top number 10A-71-2V (Does this mean a 1971 2V engine ? what about the 10A?)
    Next number: C50E-6211-A-B (Now I think this could be a 1965 bearing, but what does A-B mean?)
    Main Bearing: Top number 10A-71-P
    Next Number: C50E-6333-A-B (Again a 1965 bearing?)
    They are marked up with the Ford logo and no indication as to size so I am hoping they are standard. does anyone know?
    cheers
    Andy
    Engine started August 2011.
    1st Daughter slows progress!
    www.andysgd427.blogspot.com
  2. #2
    kdavies3's Avatar
    kdavies3 is offline Driving God
    Join Date
    May 2004
    Location
    Cowbridge, United Kingdom
    Age
    56
    Posts
    7,951
    Re: Ford bearing numbers decode...
    Ford Part Numbers:
    the part number is divided into 3 sections
    C50E-6211-A-B
    The prefix (C50E) this identifies the engine type
    The middle bit (6211) this if Fords generic number for a rod bearing and still is today.
    The suffix (AB) this identifies the actual design level of the part.
    Often bearings are colour coded to identify the various grades, this marking disappears when the engine has been run for a while, which isn't very helpful.
    Kev Davies
    South Wales Area Rep. UKCC Membership Secretary
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE,TKO 600, Old School IVA'd and truly AWESOME
  3. #3
    rsk289 is offline Chief Bottle Washer and Tea Boy
    Join Date
    Nov 2003
    Location
    Posts
    209
    If there's no size they should be standard.
    Roger
  1. Ford 302 Engine numbers
    By Richardp2447 in forum General Tech Tips & Questions
    Last Post: 17-07-06, 06:55 PM
  2. Ford 351 Cam Bearing Installation
    By Martyn-ak427 in forum Engine Tech Tips & Questions
    Last Post: 24-05-06, 05:44 AM
  3. Ford Engine Numbers - Again!!
    By Almac in forum General Tech Tips & Questions
    Last Post: 14-03-05, 07:28 PM
  4. Decode Chevy Engine Numbers
    By BILKO in forum General Cobra Discussion
    Last Post: 09-08-04, 07:57 PM
  5. Ford Engine Numbers HELP NEEDED
    By robert in forum General Cobra Discussion
    Last Post: 20-01-02, 08:19 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
