| MGB rear axle ratio change. I am in the process of changing my MGB axle ratio for the V8 one and have all the bits sitting in the workshop. My request is for any information about the process to change. I have no problems in setting up crownwheel and pinion and backlash but I have heard that this change will require some machining to the diff carrier. Hence the reason for wanting to clarify this point and maybe find someone with some direct experience. The main MG suppliers are of liitle help on this and the local transmission engineers have no recent experience of this. I would like to have the information to hand if I approach a local workshop for a setup rather than pay for them to find out. My early investigations would suggest that the carrier needs machining so that the crownwheel can sit a bit further back. Andy
__________________ A S motorsport Ltd. 01379 688356 mob; 07909531816 web; asmotorsport.co.uk email \"andrewsoar@yahoo.com\" |
| Re: MGB rear axle ratio change. I have been searching the web and established the carrier does need machining as you say. I would like to know how much! then I may have a crack at it. Where did you get yours done? I'm in South Norfolk by the way Andy
| Re: MGB rear axle ratio change. Andy, I got mine done in Newport, Shropshire. Can't remember the guy's name. I have a card somewhere but it was about 10 years ago and he was talking about retirement. If i can find it I wil try the number Gerry Hawkridge told me that he uses Hardy Engineering in Leatherhead to produce their axles; they may help you.
__________________ David Large Bald Surfer with a BRA 289 |
| Re: MGB rear axle ratio change. Andy, David is correct, check with the guys at Hardy, I have phoned them a few times and they helped each time (Hardy on 01372 378927). You may find that the case will need to be increased in size. John. |
| Re: MGB rear axle ratio change. There were no alterations needed to the case on mine as I recall. When I changed mine it was because I had to but actually I preferred the lower diff I had previously. Unless you have a lot of torque the 3.07 diff is a bit high.
| Re: MGB rear axle ratio change. I found the standard ratio too low for cruising. I am running a Rover 4.0litre with hi torque cam. I plan to set up on a rolling road eventually so i will be able to tell you the figures then but I think it is putting out toward 240hp. So far i have found up a spare diff carrier and have machined 2mm from the crownwheel mounting face. Not had a chance to try it yet but I am confident this is the right way to go. I will follow up on the contacts give by you, many thanks. Andy S
| Re: MGB rear axle ratio change. Andy, Just replied to your pm before checking the thread so sorry for asking questions in the pm you have answered here. Must learn to do things in the right order. I too run a 4.0 litre Rover 240bhp/255ftlbs and that is good with 3.07 but my last 3.5 engine was well down on torque and the 3.07 was too tall for it. Nice to hear from the 289 minority.
| Re: MGB rear axle ratio change. Things are looking promising. I managed to drop the assembly back into the housing today (less the 2mm of machining). Things are now meshing correctly and in fact the backlash happens to be about right! However this is with no shimming on one side and the old bearings so I will have to machine a bit more off. The crownwheel now has excessive runout as I suspected so I will have to get my original carrier machined out of house when I have established the amount to remove. Have not yet had a chance to chase up any of the contacts but will. Thanks Andy
| Re: MGB rear axle ratio change. Sounds like good stuff. Important to get it spot on or after few miles your diff will be able impersonate a police siren. That is what happened to me. The original diff I had (MGC) ran silently but used to clunk a bit when I engaged reverse. In a moment of "improvement blindness" I took the axle out and sent it to be reset. When I put it back in the car it whined like my mother in law! Axle out again and new diff! Different ratio which didn't suit the car so well. Rule 1 applies; If it ain't broke don't even think about fixing it
| what rear axle ratio??? | scarface | General Tech Tips & Questions | 7 | 14-08-05 08:19 PM |
| Late XJ rear axle | rsk289 | General Tech Tips & Questions | 0 | 06-09-04 04:37 PM |
| How to ID your rear axle?!? | Andy302 | General Tech Tips & Questions | 2 | 09-05-04 11:58 AM |
| Jag rear axle end float | millsd60 | General Tech Tips & Questions | 15 | 13-01-02 09:25 AM |
| Jaguar rear axle | gartrac | General Tech Tips & Questions | 2 | 19-11-01 10:10 PM |
