Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2010
    Location
    Milton Keynes
    Posts
    2
    Hawk 289 wiring loom
    Does anyone have a drawing of this loom (same kind you get in the Haynes manual books)? The information says I need to connect (for example) the brown wire to "number 4" on the headlight/sidelight switch. My loom did not come with a switch so what does this number mean?
    The manufacturer has ignored my request to purchase a copy of the relevant drawing, which I would prefer being an electronics engineer myself.
    Thanks
    Mike
  2. #2
    KevinW's Avatar
    KevinW is offline Driving God
    Join Date
    Feb 2007
    Location
    Hants
    Posts
    5,450
    ... a few 289s here, but your best bet is the 289 register....
    Crendon Chassis No.49
    Huddart FE428 + toploader
    486 ft lb / 491 HP on the brake
    460hp with Turkey Pan fitted.
    http://www.cobraclub.com/gallery/sho...hp/photo/8027/
    http://www.xtranormal.com/watch/6977111/
    Replica FPSB. Not listed in the Shelby Register.
  3. #3
    Clive's Avatar
    Clive is offline Technical Director
    Join Date
    May 2004
    Location
    Perth
    Posts
    4,176
    Hi Mike,
    There isn't a diagramatical wiring diagram for the Hawk 289 as far as I know. As far as I can remember I didn't encounter any problems wiring up my switches. I laid my wiring loom out on the garage floor and "dry fitted" the components. What switches are you using? The ones supplied had the numbers beside the terminals as far as I remember. There are only three wires on the switch and the brown is the un-fused power supply. It would be quite simple to test the switch terminals with a meter to determine which terminal was which. As said www.the289register.com is probably your best bet for Hawk related queeries.
    SVC should be able to supply the switch, but this diagram might help. LUCAS FLICK SWITCH HEADLIGHTS - My Store
    Cheers, Clive
    (If I'm not here, I'm either in my new workshop or on the golf course!)
  4. #4
    StewbieC's Avatar
    StewbieC is offline Head Mechanic
    Join Date
    Dec 2008
    Location
    Shropshire
    Posts
    832
    Hi Mike,
    Martin from ECS hasn't got a wiring diagram (to issue anyway) as I imagine that prevents people from copying his design. The loom normaly comes with the switches (mine did) If not you'd be better chasing the missing switch. Apart from some missing info with the immobiliser and some questions about the alternator connections, I found the installation pretty straight forward.
    From memory Brown is fused live. If that helps.
    Here's a link to Martins company if it's any use. Car Parts Suppliers, Rally Car & Race Car Parts For Sale, Essex UK-ECS
    I'm pretty sure this is the switch you are missing, but I'm sure Martin will confirm. https://www.electricalcarservices.co...11-p-1001.html
    Hope all goes well if not come back and we'll do our best.
    Stu
    _________________________________________
    Hawk 289 Powered by a FORD 289
    My Gallery http://www.cobraclub.com/gallery/sho...wk-289/cat/500
  5. #5
    dingocooke's Avatar
    dingocooke is offline Driving God
    Join Date
    Jul 2004
    Location
    Nottinghamshire UK
    Posts
    7,585
    Wiring diag
    Attachment 19300
    here you, although this is original style 427 wiring, it is very close to original 289
    Regards Steve
    I know there is a Betty Ford Clinic; is there a Betty Cobra Clinic.?
  1. dax wiring loom
    By cobradave09 in forum DAX Technical Questions
    Last Post: 12-01-11, 02:24 PM
  2. wiring loom
    By vinster in forum General Cobra Discussion
    Last Post: 15-12-07, 01:26 PM
  3. Wiring loom
    By Daxman in forum DAX Technical Questions
    Last Post: 03-01-07, 12:58 PM
  4. Wiring Loom Help
    By shellby_cobra in forum General Cobra Discussion
    Last Post: 21-02-05, 06:32 PM
  5. AK Wiring Loom
    By AKBandit in forum AK Technical Questions
    Last Post: 15-01-05, 07:01 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
