| Do I have a complete Exhaust system???? Have opted for the chrome side pipes and have the following bits: Outlet manifold Chromed bend Chromed side pipes Mini bobbins Cheese grater cover Big jubilee clips Mild steel strip for making support arms Escutcheon plates Having just watched the video is there another part that goes between the outlet manifold and the chromed bend?? It is difficult to tell when the video is edited down so much and the manual doesn't cover this. I could start cutting the hole and connecting the parts together but have started worrying just after Pilgrim close for the weekend! Thanks Brian P l |
| Re: Do I have a complete Exhaust system???? Brian Same thing happened to me. You are missing the two down pipes from the manifold to the first chrome bend. Pilgrim will send you them out. Rgds Phil |
| Re: Do I have a complete Exhaust system???? Thanks Phil - somehow doesn't surprise me Brian |
| Re: Do I have a complete Exhaust system???? Do your sidepipes have the baffles already inside? I had to fit mine. You won't pass SVA without.
__________________ Keith S Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5 |
| Re: Do I have a complete Exhaust system???? Hi Keith Forgot to list the baffles. I do have them although that was another part Pilgrim put to one side of me and managed to sell before I turned up to pick up the exhaust system. |
| Re: Do I have a complete Exhaust system???? Brian You also have to bash the baffles down the pipe yourself!!! Phil |
| Re: Do I have a complete Exhaust system???? that exhaust is very bad for everyday maintenance...you dont have enough room to be able to torque your exhaust...and it is not a trivial job to change some of the plugs as well...i m in the process of manufacturing new exhaust .. |
| Re: Do I have a complete Exhaust system???? I had a real nightmare tightening up the manifold myself - there isns't enough room to get a socket onto a couple of the bolts Brian |
| Re: Do I have a complete Exhaust system???? I found that by taking a standard allen key and grinding off 3/4 of the shank [the bit that goes into the socket] you can manage all manifold bolts OK. There is a sequence to tighten the bolts as some snag with the manifold if not done 1st. I'd have to take a look to remember the sequence.. |
| Unique exhaust system? | JoMo | General Cobra Discussion | 3 | 13-01-08 03:33 PM |
| Underslung exhaust system | martin_t | General Cobra Discussion | 15 | 07-02-06 11:29 AM |
| Exhaust Manifolds / System | mjculley | General Tech Tips & Questions | 2 | 20-08-03 10:48 PM |
| Exhaust System Set-up | mbrook | General Tech Tips & Questions | 8 | 07-11-02 09:23 PM |
