Old 09-02-05, 02:59 PM
Grille fitting
Hi again
Can I ask how the grilles are fitted. Just tried them for size and they are all oversize for the apertures they have to fit. Should they fit into the apertures or stay just behind. To make them fit the aperture will mean removing some fibreglass material. Is this correct??
Phil
Old 09-02-05, 04:00 PM
gareth08's Avatar
Re: Grille fitting
Phil
Main front grill goes in from behind(held mine in with 4 S/T to enable removal) other ones I glassed in from behind.
Gareth
Gareth
Old 09-02-05, 04:33 PM
Re: Grille fitting
Phil,
I found the Sumo 'grill' a bit much so changed to the single bar effect with an invisible grill 2" in from of the radiator.
Check the pictures out at my web site build:
http://www.softstar.co.uk/cobra
click on the after SVA button
Steve
Old 09-02-05, 05:11 PM
Re: Grille fitting
Also consider that grilles do restrict airflow to your radiator,so if you are going to go down that road make sure that the grill has holes big enough to let plenty of air through.
\"If Anything that i post on this site offends any person in any way possible,i categorically apologise unreservedly in advance as any distress or alarm or harassment was not my intention.I apologise wholeheartedly!!!!!\"
Old 10-02-05, 09:19 AM
CRC Member
Re: Grille fitting
They need to be oversize as they fit inside, with Silkafix (used to seal all the chassis gaps) and the main grill has 6 self tap ss screws.
I know several cars have no grill but I was concerned about rad damage and mine has not overheated in 3 yrs.
Martin
www.munderhill.co.uk
summers commin....
Old 16-02-05, 04:45 PM
Re: Grille fitting
I used 1cm square mesh from B&Q, galvanised and then sprayed it black to make it almost invisible.
Attached using stainless self tappers and small aluminium brackets to hold the mesh between the fibreglass and the brackets.
I've also got my 16 inch kenlow fan on the front of the rad to improve stone/debris protection.
I only fitted mesh to main radiator opening, left others clear which was fine for the SVA as the steel ball (simulated knee cap) cannot pass through these other openings.
David
Stainless steel grille mesh Mr Bling General Tech Tips & Questions 0 05-03-06 08:32 PM
tko fitting jordizr1 DAX Technical Questions 8 22-02-06 06:15 PM
Front Grille mesh kevchard General Tech Tips & Questions 9 11-07-05 09:04 PM
Front Grille bazbo Engine Tech Tips & Questions 3 11-03-05 10:11 PM
front overriders-grille bar dave General Tech Tips & Questions 7 07-11-02 09:24 PM
