Old 08-03-05, 12:21 PM
Number Plate Light
Hi again
I have read of people taking the wire for the light "through" the boot lid. Is this possible with the Sumo and if so are there any tricks to what looks a real fiddly job?
Phil
Old 08-03-05, 12:27 PM
gwak76's Avatar
Re: Number Plate Light
You can run the wire through the rib that runs around the edge, drill the entry and exit holes as required and dont forget the grommets.
I attached a nut to a thin wire, poked it in one of the holes then dragged it around with a magnet from the outside, two or three attempts and it was done then just pull your cables through, no nasty wires on show :thumb:
Gary
Custom Exhausts & Headers
ww.sidepipes.co.uk
Old 08-03-05, 12:41 PM
Revets's Avatar
Hi Phil,
I did this with my Sumo and yes it is fiddly - took maybe an hour. Patience required.
I used a nlyon cable puller I'd bought a few years ago from Screwfix for £5 or so. Drilled a hole in the raised part of the underside of the boot just outside the hinge. Drilled another hole at the booton just under where the light fixes and fed the puller through. Attached the cable pulled it through.
If memory serves correct there are some photos on Tony Breski's site
Steve
Old 08-03-05, 02:58 PM
Alternatively fix the wire to the inside of the boot lid with stick on cable clips (B&Q) and then glue carpet to the recessed part of the boot lid.
I also did the whole of the boot interior with the same carpet.
You need to use felt like carpet rather thab you thick Axminster in order to fit it to shape inside the wings.
Also best done outside in order to avoid being overcome by the fumes of the glue.
Unless of course you like that sort of thing.
Keith
Keith S
Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5
Old 13-03-05, 07:51 PM
ti's Avatar
ti ti is offline
Phil
If you are painting the car,the sprayer will want to take the
boot off!!!
Yes you've guessed it,it means that you get to do it all again-Happy Days!!!!!!!!
Cheers !!
Terry
Old 13-03-05, 08:19 PM
Ian Lloyd's Avatar
The Sumo demo car at Stafford this weekend had the number plate light wire run through the inner moulding on the boot.
Old 15-03-05, 01:37 PM
I used one of premier wiring's cheap 2 pole connectors along with their bi-wire (looks like speaker cable) for wring the light, have removed the bootlid several times without any wiring hassles
Kev
Old 15-03-05, 05:22 PM
Hi guys
Tried feeding the cable along the inner moulding, but got my "mouse"stuck twice (they're still in there!!) Tries various methods with various materials but failed every time. They go so far then get stuck. Tried it in both directions around the lid but still got stuck. Apart from over the top don't now my next move!!
Phil
Old 15-03-05, 05:29 PM
Miket's Avatar
Extremely Senior Member!!
Originally Posted by Phil McCann
Hi guys
Phil
Phil
I had the same problem, I eventually gave up and just fastened it to the underside of the boot lid, I managed to get away with just 1 live wire as I used the boot catch as the earth through the chassis, only problem was if you opened the boot the number plate light went out, but not a problem. :thumb: :thumb: :thumb:
Mike
Cobraless
I have a simple philosophy: Fill what's empty. Empty what's full. Scratch where it itches.
HONDA ACCORD FOR SALE
Old 15-03-05, 07:09 PM
ti's Avatar
ti ti is offline
Hi guys
Phil
Phil
Try This!!
Drill an extra hole half way, this makes it a lot easier to
find the wire, and then continue to thread through
to the bottom entry.
Then put a blanking grommet in the extra hole!!
Worked for me.
Cheers !!
Terry
BB code is On
Number Plate Light Again - last time promise pelham939 Pilgrim Sumo Technical Questions 2 21-03-07 11:01 AM
number plate simon The Cockpit 3 21-01-07 06:47 PM
Number plate light BenBaron General Tech Tips & Questions 2 14-12-06 03:42 PM
Wiring the number plate light Robin427 General Tech Tips & Questions 10 13-05-04 07:08 PM
Vin number plate BenBaron DAX Technical Questions 5 02-03-04 07:10 AM
