| Replacing the radiator? I am nearly at the SVA stage and have just been fitting all the trimmings etc, after getting he car back from being sprayed. I have unfortunately developed a leeking radiator. I am not yet sure of the cause of this but when the engine gets up to temperature I get plooms of steam coming from the radiator., and a slight trickle of coolant running down it. The radiator was brand new, as supplied bu pilgrim and it has not been bumped during the build. However whilst tinkering with the engine the other day, the top hose threw itself off under the pressure of the coolant. Could this pressure be enough to cause a small hole to form in the radiator? I've already put one small tub of radweld in, but it doesn' t seem to have done the trick. I will probably try some more, but failing that I may need to replace the radiator. has anyone done this with the body in place? How easy is it? Could anyone reccomend any other products hat are better than radweld? I'm off skiing next week, but any advice on the matter will be gratefully received. Thanks Greenster |
| Re: Replacing the radiator? Quote:
| Re: Replacing the radiator? Do you know that Pilgrim knows the general radiator the y furnish is too small for the heat to evacuate usually so they can provide a bigger one that will do a very good job...my mechanic just did the change on mine ...and i will also upgrade with an oil cooler. |
| Re: Replacing the radiator? thanks for all the feedback..will get round to sorting it later this week... greenster |
| Replacing the Windscreen | ellebarto | General Cobra Discussion | 10 | 07-10-06 09:46 PM |
| Replacing DAX seats in my Cob | emgee | DAX Technical Questions | 22 | 24-02-06 09:30 AM |
| Replacing Sierra Swichgear | Kevin_T | DAX Technical Questions | 2 | 10-11-04 05:19 PM |
| Replacing Bumpers | MetaJacko | General Tech Tips & Questions | 0 | 07-06-04 03:31 PM |
| Replacing cob engine | matt78 | Pilgrim Sumo Technical Questions | 3 | 14-07-03 12:19 PM |
