| double roll bar height hi, just fitted my double roll bars, i have looked in the pilgrim manual and it says the height for single roll bars is 215mm from the body to underside of bar, does this apply to double roll bars aswell? |
| Re: double roll bar height Hi there I think the roll bar height is critical when you come to fit the hood. I have assumed it is the same for either one or both bars, but haven't got to the hood bit yet. HTH Phil |
| Re: double roll bar height Having just done this for twin single roll over bars, I think there might be some confusion. The 215mm measurement I think, should be taken from the underside of the DOUBLE width roll over bar down to the body in between the seat belt mounts. If you have twin single roll over bars, then you have to somehow make the same measurement. I just used a spirit level and a rule, and then subtracted the width of the non-exisitent roll bar section in the middle of the car. But its a simple measurement when you ave the standard double width roll over bar. Does that make sense? btw Tony told me that you don't need to be mm perfect (as I was 2-3 mm out, told it the softop would stretch the extra distance. |
| Re: double roll bar height Should do - when Tony was showing me how they fit the hoods with double roll bars they basically clip a bit of plastic drain pipe between the hoops to support the hood.
__________________ See the build in action: http://www.sumobuild.co.uk [Now with added web 2.0 goodness!] |
| Double roll bars | cliffords | AK Technical Questions | 20 | 03-01-08 11:25 PM |
| double roll bar sumo mk2 | vinster | Wanted Adverts | 1 | 18-12-07 09:53 PM |
| Double Roll Hoops | bc_suv | Pilgrim Sumo Technical Questions | 6 | 30-03-06 12:57 PM |
| Double roll bar | bert | Pilgrim Sumo Technical Questions | 32 | 09-01-06 11:24 AM |
| roll bar height | David J | DAX Technical Questions | 4 | 25-01-04 12:38 AM |
