| Re: Failing the SVA Hi Guys, Just thought I'd let you know my fail list as just back from the SVA centre. All in all the tester made you feel very comfortable even made us a cup of coffee and complemented me on my build quality but it failed on 13 counts mostly minor and easy to fix except the steering column.
__________________ Cheers Adrian Sumo, Rover 4.0Ltr, Holley 390. Up for Sale so I can build another. |
| Re: Failing the SVA Hello, quite a list but all easily fixable I'm sure. Regarding the steering column: Did you ever read this post Classified alerts? Its quite a bit to read but at the end has some pictures of a new bracket someone made. I think Pilgrim should be informed of this if the SVA guys are failing part of the standard kit again. Anyone else passed recently with the standard bracket? Could I ask which of these failure points relating to parts are from parts that claim to be SVA friendly and are supplied that way. I'm suprised things like boot hinges and washer jets are failing if they are part of the standard kit. Best of luck with the restest!!! Cheers Graham
__________________ Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
| Re: Failing the SVA Graham, Washer jet failed due to flat edge on top, came from Europa. The Boot hinges are well known as fails, they're originally from a Hillman Imp i believe but a second pair filed down will fix it then replace when you get home. I should have known better for these.
| Re: Failing the SVA Adrian sorry to hear about your failing but I'm glad the tester was pleasant. With the steering column your bracket should look like this (see attached pic, it's the photo that's in the long post listed above) we've had ours modified to be strengthened with the fillets down the side, the column won't flex at all now. Did you use Pilgrim's 'SVA friendly kit' that they supply for the test?
__________________ Sumo SVA\'d and registered. Paint still to come. www.jgr-design.com/sumo last updated: *27.10.06* |
| Re: Failing the SVA I'm also not sure why Pilgrim don't supply a modified bracket. I know many have passed with the standard item though. I was also wondering if you could let me know what kind of spreader plate you used for the lower seatbelt mounts? We're using a modified version of the one from Europa and have cut it and are welding it to the chassis. John
| Re: Failing the SVA Hi I have my SVA booked for next Monday so some of your comments have made me go and have another look!!!!!! Regarding the top seat belt mounts. I have used the Pilgrim supplied ones and as you say the nut cover clearly fails however, taking it off leaves the nut obviuosly exposed but recessed, and all the edges around it are less than 5mm so only have to be blunted. The inner tunnel seat belt mount spreader plate, what size did you use? I have used the Europa supplied plate with welded nut, is this going to be big enough? I am hoping that Pilgrim get me an SVA kit in time as the date for my test (Derby) was only given me yesterday. This seems worse than waiting for the dentist!! Ian |
| Re: Failing the SVA Good luck Ian, have you asked any local cobra owners to have a quick look round your car before sva? It might just show up something, we all get blinkered with our pride and joys. PS make sure that when looking in the boot you can see threads protruding through the top seatbelt mounting nuts |
| Re: Failing the SVA Sorry to hear about your SVA fail, with regard to the steering column mounting I had exactly the same problem take a look at this link for some info Classified alerts? Good luck with the retest Regards Garry |
| Re: Failing the SVA Quote:
Take the pilgrim nut covers off and find a suitable size blanking grommet and glue it in place - did the trick for me !
__________________ Cheers !! Terry If It Ain't Broke Don't Fix It !! www.topclassphotographics.co.uk |
