| Re: Failing the SVA Guys, Thanks for all the good advice, I agree that Pilgrim ought to be providing a decent bracket, they certainly know about it from what it seems. Ian - As for the top seat belt mounts I am going to split a bit of rubber hose and glue it round, I might also use some Silkaflex around the nut covers just to smooth it off. The spreader plate he wanted was a triangular shape all along the flat face where the lower mounitng hole is in 3mm plate. I think what he is saying is very sensible, I wouldn't like to think of someone getting hurt in my car if it comes away, especially as I'm going to sell it once its on the road. Safetyspice - Dave B reckons your just down the road, any chance of having a look at how you've done the steering column bracket and yes it is the same SVA tester you had? Sent you a PM with my mobile on it. Rich - Where abouts is S & J as I was hopping to get the car to Stoneleigh? As for using Pilgrims SVA kit, I haven't used a lot of their parts, I have an Autobrass screen and Dax sidepipes so there wasn't much point. The Pilgrim screens a failure as there's too many sharp edges on it unless they've changed it.
__________________ Cheers Adrian Sumo, Rover 4.0Ltr, Holley 390. Up for Sale so I can build another. |
| Re: Failing the SVA The Man for VOSA, he says Yyyeeeeaaaahhhh. After all the points rasied on my failure sheet and some help form you guys my car passed its SVA yesterday and is on the road. Hoping to get a couple of niggles sorted out and drive it to Stoneleigh this weekend.
| Re: Failing the SVA Adrian Well done its a great feeling mine passed on Monday but DVLA took 2 days to come up with a reg number. L980 PTO I hope not to follow the advice of the letters. Will be at Stoneleigh tomorrow, Have not fitted the weather gear yet so hope it dont rain too hard. Congratulations maybe see you tomorrow. Ian |
| Re: Failing the SVA hi, whats this steering problem, that keeps propping up read this in an earlyier fourum .made mine out of angle and flat bar, instead off the thing you get from pilgrim, also someone going on about there steering collum, it goes in and out, up and down, so does mine and it seems fine. better than that wobbly peice of '#### from pilgrim, hey , my wife might want to drive it, if it ever gets on the road, you know what women are like, cant get close enough to the windscreen, any advice would be great, colin. |
| Re: Failing the SVA My car failed on a couple of small things which was a supprise as I fully expected it to be a lot more as I did not read the SVA guide lines. First thing was the Indicators on the front, I knew that the standard position would not conform to the height regs so i put the stalk type on the car but also left the original ones on as well. Of course they failed it because if you have a light on the car it has to be working and if it works it would fail on the height, stupid or what. Second item was the clock that I had fitted which failed on protusion of more than 9.5mm. Both these items could have been removed on sight in about 5 mins but this was not allowed and therfore rebook had to take place. money for the boys I think. Anyway all done now and enjoying loads. I think the secret is not to worry about it to much and go with the attitude of its going to fail. Antony |
| It's castor that needs adjusting for self centring
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Bad luck Graham, but not to hard to sort. As Mike says its the castor that needs to adjust but very little you can do with the sumo. Dare I say just for the SVA a couple of jublee clamps inside the rubbers to limit the steering a bit jeff
__________________ Jeff My next one is going to be AK |
