Old 15-04-05, 09:02 PM
trackrod end taper
Hi There,
Following on from a different thread,has anyone else had this problem of failing the SVA by only reversing the taper on the hub and not fitting a bush and then tapering?
If it needs a bush what size etc have people used.
Just a thought, but would it be possible/OK to weld up part of the original taper,drill to correct dia,and do the new taper.Or should I put my boots on,go outside, and feed my horse!!!!!!
cheers
Steve
Steve Fawlty:drive:
When will it ever be finished??!!
Old 20-04-05, 03:34 PM
Re: trackrod end taper
How can you taper a bush?
See the build in action:
http://www.sumobuild.co.uk
Old 20-04-05, 03:57 PM
Hi There,
I was following on from a post the other day(failing SVA)I had never heard of this problem/solution.Having spoken to pilgrim it appears they have sorted this out with the SVA and reversing the taper will now pass
Steve
Steve Fawlty:drive:
Taper reamer for steering arm???? JoMo General Cobra Discussion 2 20-09-07 05:02 PM
taper drill (HEELLLLPPPP!!!!!!) herberry General Cobra Discussion 9 30-11-03 03:01 PM
question for sierra-based Sumo owners re taper drill interestedparty General Tech Tips & Questions 7 17-11-02 06:08 PM
7 Degree Taper Drill Wanted !!! Adrian The Loan Forum 1 01-07-02 08:25 PM
