| Suspension Bolts Hi again Have just stripped the suspension AGAIN. Had to change the two bottom swing arm fixings on each side for 80mm bolts to satisfy the two thread rule. However, checked the joint on the mushroom and sure as hell it does not comply either. Apart from new mushrooms from Pilgrim are there any other solutions?? I also noticed at the other end of that track rod after it has screwed through the swing arm, the locknut, albeit not a Nyloc, doesn't have two threads showing. Is this important for SVA?? Cheers Phil |
| Re: Suspension Bolts Quote:
I Have heard of people cutting down the nut so the threads protrude more, i would not suggest any-one does this as it will weaken the joint !! I think that getting new one's from pilgrim would be best,no point in taking chances. As to the threads on the swing arm,mine is the same and i am not sure if this applies. Maybe some-one could let us know ?!?! I have attatched a pic
__________________ Cheers !! Terry If It Ain't Broke Don't Fix It !! www.topclassphotographics.co.uk |
| Re: Suspension Bolts Phil Heres the attatchment
| Re: Suspension Bolts Hey Terry - nice discs!! Phil - have a look at my post about this from last week. This was the easiest and quickest solution for me. Classified alerts? Alan
__________________ Sumo - 302Windsor - Tremec TR3550 SVA Passed, Registration here and on the road......yeehaa! Now where\'s the sun? |
| Re: Suspension Bolts Terry, Nice discs, it should stop OK! Hope your'e not using a 'bog standard' Sierra diff with that 351 !! |
The answer to your question about the diff-I'm afraid so 'Bog standard ' Any other ideas as to how to up-rate this ??
| Jag Suspension + stainless steel nuts & Bolts | martin_t | General Tech Tips & Questions | 7 | 06-01-07 06:54 PM |
| Help with Bolts for SD1 | martin_t | Engine Tech Tips & Questions | 16 | 12-07-06 12:34 AM |
| stainless suspension bolts | simon | General Cobra Discussion | 30 | 27-03-05 11:37 AM |
| Bolts | Goldie | General Tech Tips & Questions | 9 | 31-08-04 11:21 PM |
| Chevy 2 bolts VS 4 bolts | Jesus | General Tech Tips & Questions | 8 | 07-11-02 09:26 PM |
