| Alternator bracket on RV8 What do I need to use to attach the alternator to the Pilgrim-supplied bracket? Is it simply a bolt of a suitable length and diameter? EDIT - Should explain, I'm talking about the bottom fixing the alternator pivots on, not the fixing it to the strip with the slot in it.
__________________ See the build in action: http://www.sumobuild.co.uk [Now with added web 2.0 goodness!] |
| Re: Alternator bracket on RV8 I couldn't get the Pilgrim bracket to line up properly, and it put the alternator out of alignment. I found the normal rover P6 mount worked well in conjunction with an alternator from an XR2 (H reg) Best of luck David |
| Alternator for v8 rover and bracket advice for dax | markieboy | General Tech Tips & Questions | 1 | 02-01-06 06:54 PM |
| 351 Cleveland alternator bracket | KCC owner | General Cobra Discussion | 12 | 26-01-05 10:26 PM |
| Alternator bracket | richardd | General Tech Tips & Questions | 0 | 07-11-04 03:24 PM |
| alternator bracket rv8 | fcukruss | AK Technical Questions | 1 | 20-11-03 07:46 PM |
| Alternator bracket (Rover V8 - AK) | DrFelch | General Tech Tips & Questions | 22 | 20-11-02 04:14 PM |
