  #21 (permalink)
Old 15-06-05, 05:32 PM
Andy S's Avatar
Re: Less than 24 hours to SVA but have one last question
Probably standing in a line at some DVLA office trying to get his registration plates
Come on Antony put us out of suspense how did you get on ??????
Andy S (Maggot)
SRV8 + CHEVY
Isnt it a beautiful day - now watch some bastard louse it up !
  #22 (permalink)
Old 15-06-05, 05:35 PM
They'll be shut by now.....
In the pub perhaps with a pint staring at a sheet of 'dangerous' SVA fails. All those sharp edges!
  #23 (permalink)
Old 15-06-05, 05:59 PM
I can see that the suspense is killing you all so her goes. After getting absolutly soaked this morning on the way to the test it all started at 8.00 dead. Speedo was perfect only 2mph out so well in the allowances. Noise was just under with 1db to spare and all was looking great.
However like I expected it to it did indeed fail but only on four very minor things
1. End of rear nudge bar to sharp
2. No locking wire in rear brake caliper bolts
3. He pulled handbrake so hard the adjuster slipped and was now slack
4. Declared axle design weight wasnt high enough for calculated weight
I have now rectified all the above by moving the rera reflector, tightening handbrake again, wired the bolts and got a fax from pilgrim stating a higher front axle design weight. ITs booked for the retest at 3.00 tomorrow so this time tomorrow il have my MAC.
Just awaiting a DVLA inspection now and bobs your uncle all done.
Thanks for all your kind words and support, its great to see MIke T is back and it will be good to catch up with the illusive man himself.
Regarding the £25K build cost I think its fair to say my spec is alot higher than that of pilgrims, and all there build and design faults have been removed from my kit which themselves needed some financing
Anthony
ANTHONY
Pro cobra builder
Current build No. 16
  #24 (permalink)
Old 15-06-05, 06:23 PM
gwak76's Avatar
See, not that bad at all
Strange you should mention nudge bars, I ground the ends and put a small radius on them, not that it's much use telling you now
Gary
Custom Exhausts & Headers
ww.sidepipes.co.uk
  #25 (permalink)
Old 15-06-05, 07:13 PM
ti's Avatar
ti ti is offline
Well done Anthony
Did you go to Taunton ?
I think this will be my choice rather than Exeter !
All the best for tomorrow ! :thumb: :thumb:
Cheers !!
Terry
  #26 (permalink)
Old 15-06-05, 08:43 PM
Thanks Gary I decided on moving the reflector and covering the sharp edge instead of grinding shiny expensive chrome.
I used taunton, the chap was very helpful, let me use the ramp to rectify some other minor defects and even gave me a push after the fans had drained the battery and it wouldnt re start.
Thank you all again for your support throughout my build
Anthony
ANTHONY
Pro cobra builder
  #27 (permalink)
Old 15-06-05, 10:40 PM
steamyrotter's Avatar
Serial Complicator
good luck tomorrow m8
Dean.
  #28 (permalink)
Old 15-06-05, 11:36 PM
Yes Good luck, :thumb: but as well as emptying your first tank of fuel can you take a moment out to keep us all informed.
  #29 (permalink)
Old 16-06-05, 11:58 AM
Well done. A few minor items easily fixed.
On the calipers bolts issue, I wired the bolts on the jag rear calipers on my first build, but on the next two I have used spring washers under the bolts as I was under the impression that as long as some type of locking or anti-vibration method was used the SVA engineer would be happy. Should I put in locking wire as a second failsafe method?
Tony
  #30 (permalink)
Old 16-06-05, 12:40 PM
Tony
If the bolts are drilled for locking wire they must be wired, if they are not drilled then your ok
Last 24 hours posts Miket Admin Announcements 13 16-02-07 03:07 PM
Something to while away the hours this weekend...... oglyoodoo The Cockpit 0 21-12-06 10:20 AM
Hours of fun (sorry if posted before)!!! the rock doc The Cockpit 0 29-07-06 09:49 AM
Le Mans 24 hours 2005 kdavies3 General Cobra Discussion 263 13-06-05 04:49 PM
Around The World In 80 Hours mclark General Cobra Discussion 3 17-08-03 09:13 PM
