Old 16-06-05, 01:03 PM
Sumo front caster
Hi everyone,
Just wanted to know if any one has experienced the same problem as myself. I'm currently running a Chevy 350 in my Granada based Sumo Mk3. The problem I'm encountering is very light steering at motoway speeds, which as you all know feels unsafe over any rough roads or bumps. The set up has been done by a very good company called Northhamton Motor Sport which has made a massive difference to my Sumo but still is far to light. The answer I've been told is to have more caster, but as we have gone to the maximum that the Sumo can extend to (which is not much) the answer seems to point at some modification on the lower wish bone etc. So cut along story short has any one encountered the same and did you over come this problem?
Many thanks.
Old 16-06-05, 01:21 PM
gwak76's Avatar
Re: Sumo front caster
You may find it easier to adjust/ trim the top wishbone pivot tube attached to the chassis and pack the wishbone as required, we are only talking mm here. That will allow castor change without too much effort even when setting up.
Not the only option I know but easiest me thinks
Gary
Custom Exhausts & Headers
ww.sidepipes.co.uk
Old 16-06-05, 03:41 PM
Thanks Gary,
Did you have this problem yourself or is this just part of the Sumo set - up do you think. I also have a lot of bump steer which can be anoying any suggestions ?
Thanks again Gary
Old 16-06-05, 04:13 PM
gwak76's Avatar
William
resolved my caster problems this way, only a smidge taken off the drivers side, both sides are now spot on.
Bump steer, have a look at the link below, not too complicated and I am sure it can be resolved, just time and effort. I can't imagine the Sumo front end having all those angles lined up, good winter project
http://www.racerpartswholesale.com/longtech3.htm
Gary
ww.sidepipes.co.uk
Old 16-06-05, 09:35 PM
Cheers Gary,
Any one you can recomend to carry this work out, trouble is l live in Buckinghamshire area, near Watford ?
Thanks Mate
Old 17-06-05, 04:08 AM
gwak76's Avatar
Dont know your area too well so I can't recomend anyone, sure there are some folk on the forum who do though, come on guys help needed :thumb:
Gary
ww.sidepipes.co.uk
caster angle,mk2 sumo. grizzly_a58 Pilgrim Sumo Technical Questions 5 15-08-07 09:11 PM
Sumo 3 light front end steve14 General Tech Tips & Questions 66 11-07-07 09:47 PM
Sumo FRONT suspension set up Kevin W Pilgrim Sumo Technical Questions 1 24-01-06 01:47 PM
Jag front suspension Caster Shims rover General Tech Tips & Questions 9 25-07-05 10:10 PM
Sumo Front Toe Bob General Tech Tips & Questions 3 21-11-01 05:12 PM
