Old 24-06-05, 06:46 PM
windscreen
ive bought a brasscraft windscreen and i am trying to fit it,but when inserting through body the arms hit the sumo hinges. i think i should have modified hinges but after spending forever lining up doors i cant face removing them. do i cut the arms shorter?any tips appreciated
Old 24-06-05, 06:53 PM
Club Sec/Rep Liason
Re: windscreen
I'm guessing (as I once bought a Pilgrim screen) That only the 4-5" of pillar protruding through the body are actually needed for fixing. So cut them I had to do this with an Autobrass screen on the AK
AK 427 351C T5wc
Old 24-06-05, 06:54 PM
Re: windscreen
Are you sure you have fitted the door hinges in the correct holes and on the outside of the chassis, My hinges are approx 2 inches below my windscreen mounting arms.
Anthony
ANTHONY
Pro cobra builder
Current build No. 16
Old 24-06-05, 07:15 PM
Re: windscreen
yes all in correct position . on the brasscraft screen the arms are about 12"long and slightly catch the corner of the hinge which is further down fromthe fixing slots, ithink iwill have to cut them but it would have been nice to have a extra fixing further down
Old 25-06-05, 11:06 AM
ti's Avatar
ti ti is offline
Re: windscreen
I HAD THE SAME PROBLEM !
I CUT THEM AND NO PROBS ! :thumb:
Cheers !!
Terry
Old 25-06-05, 05:23 PM
gareth08's Avatar
Re: windscreen
Hi,
If everything is fitted correctly then all you should have to do is just cut a small notch in each of the windscreen pillars where they just catch the door hinge.Do NOT cut the arms down so that they are above the door hinge as you will find that the windscreen will move about when you drive it as the fulcrum/lowest fixing point is not enough to support the screen.
Gareth
Gareth
Old 26-06-05, 06:59 AM
CRC Member
Re: windscreen
I agree with Gareth, I took off a strip approx 1cm x 15cm long to clear the hinge.
Screen now solid, and a good job as passengers have a habbit of pulling on the screen to get out of the car.
:angry: :angry:
Martin
www.munderhill.co.uk
summers commin....
Old 26-06-05, 06:13 PM
Re: windscreen
thanks every one, ive done exactly what martin427 as done fitted perfect.
What does this Windscreen fit? kevchard General Cobra Discussion 50 19-08-07 01:00 AM
Windscreen again David Large General Cobra Discussion 8 22-06-07 06:05 PM
Ak Windscreen Carl L AK Technical Questions 13 02-03-07 06:40 PM
windscreen fit MR JONES DAX Technical Questions 6 07-06-05 06:34 PM
Which Windscreen? David Parkes General Tech Tips & Questions 1 04-05-04 10:19 AM
