| Windscreen centre stay Spent all day in the garage tinkering and cleaning the cobra meticulously. After tightening a few things up I also noticed the windscreen had become loose on its mounts and that at high speeds its rubbing the centre of the scuttle. I have seen a few cobras with a stay in the middle that hooks on the top of the screen and bolts down behind the interior mirror. Any ideas where I can get one of these preferably chrome or stainless so that I can minimise the vibration and movement. Thanks in advance Anthony
__________________ ANTHONY Pro cobra builder Current build No. 16 |
| Re: Windscreen centre stay Hi Anthony Do you realise that you will have to take you screen out to fit one. Picture shows the reason P.S must clean there, never noticed it till now
| Re: Windscreen centre stay Thanks chaps good job I checked back before I ordered one. Think il get the Dax one as I know for sure that the windscreen is staying put its a right nightmare to remove it so the Dax item it is Anthony
| Re: Windscreen centre stay Hi Mike, Where did you get the lower bracket from (screen to scuttle) for your centre stay? GD have only supplied me with the upper bracket (stay to screen). Is it necessary to have the stay fixed to the scuttle? or can I make do with the centre stay fixed between the screen frame?...the screws that have been supplied are very small and would probably not be long enough to go through 2 brackets and have enough thread to fix to the screen. many thanks Phil |
| Re: Windscreen centre stay Quote:
Got the complete lot from Brasscraft, personally I would go for the fitting that goes on the scuttle if you are using a hood, there is a hell of a build up of pressure inside which will tend to lift the frame of the top of the windscreen. if you are not fitting a hood, I suppose the stay between both frames will do.
| Re: Windscreen centre stay Thanks Mike, Centre angle bracket and longer screws ordered from brasscraft (01252782702). total cost £11.75 ...oh well better safe than sorry! If anyone else is stuck the 2 brackets are known as the "centre stay bracket" (upper bracket connecting stay to screen) and the "centre angle bracket" (lower bracket connecting screen to scuttle). thanks again Phil |
| Re: Windscreen centre stay I have a redundant one you can have for not a lot of money - email me at cpn@thelearningcurve.co.uk. Regards Colin |
| Centre stay mirrors | rich | General Cobra Discussion | 42 | 23-12-07 08:39 PM |
| Boot stay mounting | dingocooke | Crendon Technical Questions | 16 | 09-10-07 05:09 PM |
| Stoneleigh - Places to stay - Anyone Camping? | V8 BJC | Events | 3 | 07-04-07 04:27 PM |
| bonnet/boot stay | 427sc | General Cobra Discussion | 1 | 20-11-05 09:53 PM |
| Bonnet/Boot stay | 427sc | General Tech Tips & Questions | 9 | 17-10-03 10:56 AM |
