| Re: Failed SVA - A new one! So when is a glove box not a glove box and why did it fail for being a shelf when it wouldn't have failed as a glove box?
| Re: Failed SVA - A new one! Hi Johnny, To quote the failure notice "Dashboard shelf has a part facing into the vehicle that is not 25mm high and edges not rounded to a radius of curvature of not less than 3.2mm". It failed because the distance from the bottom edge of the dash to the bottom of the glovebox, sorry shelf, is not 25mm. I guess if it had been a glovebox all that would be required is raduising to 2.5mm, which it is. So the solution is to fit a hinged flap or some sort of cover over the opening and hey presto your glovebox is then officially a glovebox and not a shelf. Makes lots of sense and converts a dangerous vehicle into a safe one! Steve |
| Re: Failed SVA - A new one! Unbelievable. Testers have gone to an all time low with this. An f***ing shelf?
__________________ Sumo SVA\'d and registered. Paint still to come. www.jgr-design.com/sumo last updated: *27.10.06* |
| Re: Failed SVA - A new one! Sorry you failed but at least it's easy to fix. I think this is another example of how pathetic the SVA and VOSA are becoming with regards to the SVA. I,m beginning to wonder if the big car manufacturers are putting pressure on them to stop the smaller and amatuer builders from trading or wheather it is just another tax ploy.Either way it's a f***ing joke :angry:
__________________ Gareth Lovell 427 |
| Re: Failed SVA - A new one! Thanks guys, Couldn't agree more, especially when you see newish vehicles on the road that have a Type Approval but would fail SVA! If you know the rules you can play by them, trouble is they change the rules or rather how they are interpreted. At least with this website the word can be spread. Steve |
| Re: Failed SVA - A new one! I agree, sorry about the failure, though you can sleep well now knowing that if ever you drop your keys in the footwell, you won't smash your brains out on that lethal shelf when picking them up!!! Could you explain a bit more about the problem with your nuts please? For the flexi pipes I have them coming out of the caliper with a lock nut against the caliper, then the flexi is attached to the chassis at the top of the wheel arch with a metal bracket. The copper (female flare) is attached to the flexi with a brass coupler. The flexi is attached to the bracket with another lock nut. I don't have anthing attached to the rear suspension. Is this ok does anyone know? Digital Photo attached, used my 0.0001 Mega-pixel camera. :thumb: Thanks a million Chedz
__________________ Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
| Re: Failed SVA - A new one! Hi Chedz, As to my problematic nuts, well at least the ones I want to tell you about. I'll post a photo in the next day or so, much easier than trying to explain. As to your set-up, the brass coupler presumably clamps the female flare of the copper pipe against the male end of the flexi pipe then I reckon you're OK as long as the tester can see a gap between the brass coupler and any locknut you are using to secure the flexi to the bracket (or the bracket itself). In other words he can see you've been able to tighten the brass coupler sufficiently and not prevented from doing so by the locknut being there. Hope that makes sense. Steve |
| Re: Failed SVA - A new one! Super, the gap between my nuts is more than sufficient. Thanks.
| Re: Failed SVA - A new one! i guess there'd be 'no problem ' putting on a 1mm nut to secure this hose as long a ''2 threads were showing'' eh???!!!!!! SVA rules -i'm sure common sense should though!! NEIL |
| Failed pre SVA MOT | kevchard | Viper Tech Forum | 8 | 02-08-07 09:08 PM |
| Failed SVA | stevey | General Cobra Discussion | 3 | 21-04-07 09:16 PM |
| Help! Failed Pre-SVA MOT! | johnnycobra | General Tech Tips & Questions | 6 | 11-07-04 06:42 PM |
| SVA - Failed! | SWP952 | General Cobra Discussion | 6 | 28-11-03 03:18 PM |
| Failed SVA!-help | Dax SC | General Cobra Discussion | 5 | 28-08-03 01:51 PM |
