| Pilgrim/RV8 Fan Belt Can anyone tell me what model/make application of fan belt I need, RV8 (SD1) with Pilgrim alternator bracket, I have measured it (1030 x 9.5mm) but Halfords can't cope with that. They didn't have one that size in stock and I don't know what to order. I asked Pilgrim but they didn't seem to know!!?? Unfortunately there is no other decent motor factor nearby. QK |
| Re: Pilgrim/RV8 Fan Belt This link will give you the standard width letter for v-belts.... http://www.engineersedge.com/xbelt_size.htm A piece of string and tape measure will give you the length. Or try this... http://www.gizmology.net/pulleysbelts.htm
| Re: Pilgrim/RV8 Fan Belt The answer is not to go to Halfords. Find your local motor factors who will sell you one by length. Pilgrim recommend 1100mm, but I have found that doesn't leave much room left in the slot on the bracket to further tighten it once it's run in.
__________________ See the build in action: http://www.sumobuild.co.uk [Now with added web 2.0 goodness!] |
| Re: Pilgrim/RV8 Fan Belt Choose a local independent motor factor and buy by the length its printed on the packet - ignore the make/model that its made for I'll see if Ican remeber the name of where i got mine from but its something like Classic Spares on Southwell Road Mansfield Notts and he has a web site and deals on e-bay :thumb:
__________________ Ian Gascoigne Whether its broken or not fix it |
| Re: Pilgrim/RV8 Fan Belt Mine came from Halfords and I had the same problem. I changed it twice till I got the right size. It is written on it, but deep in the works now. |
| Re: Pilgrim/RV8 Fan Belt Thanks for all that, unfortunately we don't have a local motor factors in the vicinity (40 miles at a guess) and Halfords stock was pants, I really need an application to order one or a web site for a supplier ..... QK |
| Re: Pilgrim/RV8 Fan Belt Try VS1050 as the code for the fanbelt. That was what fitted my old Sumo with RV8 and pilgrim alternator bracket as per yours. Should be able to use that code at Halfords or most any Motor Factors with success.
| Re: Pilgrim/RV8 Fan Belt mailto:martin@partsforoldercars.co.uk Found it Fittapart Ltd 1 Southwell Road Mansfield 01623658041 the e-mail address is above and he has an e-bay shop good guy helps a lot names Martin and does mail order
| Seat belt | bert | Pilgrim Sumo Technical Questions | 18 | 08-10-05 07:51 AM |
| V Belt size | Daxter | General Tech Tips & Questions | 3 | 07-08-04 10:04 PM |
| Fan belt | tonym | Pilgrim Sumo Technical Questions | 7 | 04-06-04 08:32 AM |
| Chevy V-Belt "Fan belt" | SimonP | General Tech Tips & Questions | 16 | 23-03-04 09:03 AM |
| Correct Fan Belt | wilf | General Cobra Discussion | 2 | 07-11-02 09:11 PM |
