| Excessive brake travel ? I have an XR4i pedal box, servo and new master cylinder, with jag XJ 6 brakes, all with new pistons and seals. I've bled them twice and the pedal is very firm ... eventually ... That's the problem, I have about 40mm of free travel before the brakes operate. Is this because I'm driving 12 pistons with a master designed for 4, so no solution, or is there something I can do ? |
| Re: Excessive brake travel ? hi if you can ...use hose clamps (that temporarily clamp the hose ) and isolate each corner ,to highlight which wheels the problem.then when you bleed, if you can also push all pistons fully home ie evacuate all the gaps available for air to get trapped in. so wedge caliper pistons -be carefull of your dust seals. and clamp brake shoes together to do the same with these pistons(you can put a sdrew driver between the piston and shoe , rotate the piston 90 degrees to stop the shoe going in the slot,maybe even wedging to help. all this stops air getting trapped where it can't get 'out' it helps!!! this may or may not be your problem....... now is your master cylinder returning fully home?? if not you won't uncover the 'port' that leads to the reservoir...also not good..... so a few things to check?? good luck NEIL |
| Re: Excessive brake travel ? I guess I get around 30 to 40 mm at the pedal, but they are firm and it will lock the wheels evenly without pumping. If it dosent feel spongy and you dont need to pump them up then I'd leave them alone unless it bothers you. If you want to check if its OK take it to a tyre place and get the efficiency tested on each wheel and see if they are even. Mike |
| Re: Excessive brake travel ? hi guys sorry i just reread the post ...of course you'll be needing to push all the pistons in ...then bleed it of course...DOH!! but some still applies..clamp each wheels' hose to identify the culprit..then you can concentrate on the worst /only bad one instead of wasting time.... NEIL |
| Re: Excessive brake travel ? Hi Sid. I guess it was you I spoke to at Brands on Saturday I don't think it's a 4 piston 12 piston thing, as many manufacturers use a similar setup (AK - Escort/Marina. Dax - Escort, Etc) all with Jag calipers. You may find that it is just that the pads are not yet bedded in
| Re: Excessive brake travel ? Clamp each flexable pipe then bleed one at a time starting furthest away fron the master cyl useualy works:thumb: :thumb: Graham
__________________ Nature has one eternal grin Cobra drivers have two:drive: |
| Re: Excessive brake travel ? I am still a bit confused. I had a check last night after the post. By Beamer gives about 40 mm before the brakes bite and my brother in-laws Mondeo is over 50 mm. These are all at the pedal. Does the pedal feel spongy. Engine on tickover push the brake hard - does the pedal want to dissapear to the floor. Also can you pump it up or not. Sorry but if you have a good pedal I think you could be barking up the wrong tree unless I have misunderstood you. Dave Brooks build a lot of Cobras and as I dont think it gives a monkeys how many pistons you have I would ask him for a general view Mike |
| Brake Pedal Travel | v8robert | General Tech Tips & Questions | 5 | 14-07-05 03:41 PM |
| Lots of travel on brake pedal... | duncanh | Pilgrim Sumo Technical Questions | 5 | 29-07-04 07:56 AM |
| Brake travel | Miket | AK Technical Questions | 3 | 14-06-04 10:45 PM |
| Shortening Brake Pedal Travel | TonyD | General Tech Tips & Questions | 7 | 24-04-03 04:50 PM |
| Excess Brake pedal travel | Martin427 | General Tech Tips & Questions | 6 | 14-11-01 08:35 AM |
