| Re: Pilgrim V8 Rover exhaust manifolds The final bit of the pipe sits about 1"-1.25" in front of the bulkhead, so if you've move the engine further back than that you'll have problems. Even if that fits, I think you'll have problems with the headers catching on the steering column. I'm suffering and I've got the engine in the normal position (the problem is it's not quite straight in the bay!). You're more than likely going to need something custom made to bend around the upper/lower column joint. See the latest stuff on my site (http://www.sumobuild.co.uk/chapter17.htm) to see how close the standard fit is.
__________________ See the build in action: http://www.sumobuild.co.uk [Now with added web 2.0 goodness!] |
| Re: Pilgrim V8 Rover exhaust manifolds I had the problem with the steering column fouling the exhaust manifold. I had to buy some 1cm steel from a metal factor and build up the engine mounts. It's fine now. |
| Pilgrim Manifolds | bc_suv | Pilgrim Sumo Technical Questions | 8 | 30-10-07 10:49 AM |
| Wanted MGB V8 Exhaust manifolds for Rover V8 | Dixie | Engine Tech Tips & Questions | 0 | 04-05-07 10:45 PM |
| Sumo Rover V8 exhaust manifolds | westy | Pilgrim Sumo Technical Questions | 5 | 16-03-07 11:35 AM |
| Exhaust manifolds | jools | General Cobra Discussion | 2 | 09-01-06 05:16 PM |
| Exhaust manifolds V8 Rover | markieboy | General Cobra Discussion | 12 | 06-06-03 05:06 PM |
