Old 22-10-05, 10:03 AM
Protecting the clutch cable
Has anyone got a neat solution for preventing the clutch cable rubbing on the electrical connections on the back of the starter motor solenoid?
Many thanks
QK
Old 22-10-05, 12:52 PM
stevee8's Avatar
CRC Wessex Area Rep
Re: Protecting the clutch cable
Re route it or sleeve the cable in some rubber hose or cap the terminals with a rubber boot?
Steve
Old 23-10-05, 12:48 AM
QK we're in the process of finding a solution for this. We've managed to route it so it doesn't rub anywhere at the moment but are thinking of making some sort of bracket to hold it in place off anything important. I'll let you know what we do.
John
Sumo SVA\'d and registered.
Paint still to come.
www.jgr-design.com/sumo last updated: *27.10.06*
Old 24-10-05, 07:27 AM
I had to encase the electrical cables in convoluted tubing (SVA failure), but I also wrapped a Plumbers soldering mat around the clutch cable to prevent it melting - held on with wire, and wrapped the manifold in exhaust wrap.
Richard
\'Semper in faecibes sole profundum variat\'
Old 24-10-05, 02:51 PM
Richard, did you fail for having the cables in the tubing or for not having them in the tubing?
Old 24-10-05, 09:21 PM
John, it was for NOT having the cabling sleeved - all of it - every exposed bit. This seems to be Southamptons area of focus. Wasn't a long job, and I agreed that it should go on some of the cables - speedo wire to sensor, but not every last bit - it was a tad excessive I thought.
All details of SVA posted into failing the SVA sticky topic.
Richard
clutch cable cwdm Pilgrim Sumo Technical Questions 8 28-10-07 11:44 PM
Rv8 clutch cable Stu J Pilgrim Sumo Technical Questions 8 22-08-07 02:29 PM
clutch cable Tony Cobra Pilgrim Sumo Technical Questions 1 30-09-06 06:00 AM
Clutch Cable Phil McCann Pilgrim Sumo Technical Questions 13 08-10-04 07:47 PM
Which Clutch Cable ? beanpole Pilgrim Sumo Technical Questions 2 30-04-03 08:11 PM
