| Engine mounts Hi All, Wonder if you can answer a question which is puzzling me. I've opted to put a RV8 into my Sumo (for one reason or another) and have just trial fitted the engine today. however the distance across the engine mounts appear to be far too wide to ensure that they land on each of the chasis members. The engine mounts are the bracket type with the rectangular rubber at each end rather than the "cotton reel" type of mount. Has anyone out there used this type of RV8 engine mount and if so how did they get araound the distance problem. Also the drivers side mount is very close to the steering column. Should I opt for the "cotton reel" type of engine mounting? Regards Martsam |
| Re: Engine mounts Hi Stue, The problem Ie chassis members have is that the brackets I have made up (which are tight to the SD1 mounts) do not fall onto the chassis members. Any photos would be welcome of how the welded attachments are attached to the chassis. Thanks for the reply. Martsam |
| Re: Engine mounts Stu e, Thanks for the offer. I hope to have the problem sorted by then (he says). Wonder if you can confirm whether the welded brackets actually are welded to the chassis members or has a plate been added onto which the brackets are welded. Regards Martsam |
| Re: Engine mounts HI The welded brackets are direct onto the straight chassis members. The fillets are where the front to back members meet the angled ones the fillet welds onthe front of the join to give extra strength in that area, if I remember correctly the mount barely touches the fillet.. One thing I forgot to do was put the oil filter on when positioning the engine and had to fit a remote one, one of the lessons learnt along the way. Cheers Stu. |
| engine mounts | 427sc | General Cobra Discussion | 3 | 06-05-06 01:43 PM |
| Engine Mounts | PaulF | General Tech Tips & Questions | 4 | 05-01-05 09:31 PM |
| RV8 ENGINE MOUNTS | adyv8 | Pilgrim Sumo Technical Questions | 6 | 09-02-04 07:58 AM |
| RV8 Engine Mounts For A Dax | BenBaron | General Tech Tips & Questions | 3 | 28-12-02 04:25 PM |
| Dax engine mounts | David | General Tech Tips & Questions | 1 | 22-08-01 01:31 PM |
