Old 26-09-06, 01:41 PM
Sidecarbod's Avatar
Removing the hub flange thingy (Granada based MkIII)
Hi Guys,
I would like to remove the flange from the rear stub axle, (the part that the disk butts up against, which also has the 5 bolt holes for the wheel bolts).
I've removed the big nut in the middle and can sort of move the flange a few mm on the splined shaft but then it stops. I did not build the car so I have no idea how this bit is supposed to come off.
Any help would be most appreciated.
Regards,
Pete
Old 26-09-06, 02:49 PM
gareth08's Avatar
Re: Removing the hub flange thingy (Granada based MkIII)
Originally Posted by Sidecarbod
Hi Guys,
Regards,
Pete
Pete,
I assume you already have the caliper etc removed .
The actual hub itself is on splines on the driveshaft and should pull off once the above and big nut are removed.
They sometimes stick on the splines/seals/bearing so a little persuasion is often needed with a soft headed hammer to get them off.
HTH
Gareth
Old 26-09-06, 03:13 PM
Sidecarbod's Avatar
Originally Posted by gareth08
Pete,
HTH
Hi Gareth,
You assume right, I've taken the disk and caliper off. I was actually using a screw driver as a sort of wedge by tapping it between the flange and the housing that has the bearing in it. I guess I just need to "tap" it a bit harder!
Thanks for the quick response.
Pete.
Old 26-09-06, 03:41 PM
On a different note ...... Does anyone know the PCD measurment of the Granada 5 stud hub? I bought a rolling chasis with Ford 5 stud hub on but not sure if it's Granada or Sierra? Do they make a sierra 5 stud would that be different to a Granada?
Thanks in advance
Nick
Old 26-09-06, 05:07 PM
gwak76's Avatar
Nick
PCD chart attached
Pete
Hub puller worked for me some time back, right tight little buggers to remove.
Gary
Custom Exhausts & Headers
ww.sidepipes.co.uk
Old 26-09-06, 08:22 PM
Sidecarbod's Avatar
Originally Posted by gwak76
Nick
PCD chart attached
Pete
Hi Gary,
I reckon your right, a puller of some description is in order. I just wanted to confirm via the forum that the big nut is the only thing that holds the flange/hub thingy onto the shaft.
Thanks to everyone for your advice,
Pete.
Old 27-09-06, 11:45 AM
Thanks "gwak76" for the PCD chart.
Do you think I'm right in assuming that if it is a 5 stud Ford it is a Scoprio(New Granada) with a PCD of 112 as the sierra is only 4 stud and the Ford probe is Front wheel drive so would not be on the rolling chassis?
Thanks for your help
Nick
Old 27-09-06, 12:50 PM
gwak76's Avatar
Nick
Granada / Scorpio is my bet, don't know of a kit that used the Probe as running gear. What chassis have you got ?
Gary
ww.sidepipes.co.uk
Old 27-09-06, 03:56 PM
Mk3 sumo so I've been told (see picuture) I bought it as it stands last year like you see in the picture.
Nick
Old 27-09-06, 04:40 PM
Hi Nick,
Yup... that is a MkIII alright.....
Also, if it has 5 stud disks on the rear is is certainly Granada running gear...
All the best,
If only life was as kind to me as my wife is....
Granada Based rear axle.... janandchris Pilgrim Sumo Technical Questions 10 13-09-07 05:52 AM
Granada based Sumo AllanR Pilgrim Sumo Technical Questions 3 02-04-03 06:37 PM
Granada Based Sumo Owners - Beware !!!!! Mike H The Cockpit 1 31-03-03 05:58 PM
Crewe Based Sumo MKIII Adrian General Cobra Discussion 10 07-11-02 08:37 PM
Sumo Granada based diff choice fakesnake General Tech Tips & Questions 10 08-01-02 10:49 AM
