| Inner wing panel heat protection Hi, We fitted the inner wing panels to stop the heat from the engine bay getting into the cockpit. To do this we bonded in aluminium panels and then used a layer of ceramic aluminium coated heat mat which we bought from Car Builder's Solutions. Now there is no heat at all getting through to the cockpit. I just thought I'd let you know about the heat mat because it's a really useful item and I remember a post a while ago about someone asking what the best option for heat prevention would be. That's my recommendation, John
__________________ Mark III Sumo SVA'd, registered and on the road! |
| Re: Inner wing panel heat protection Garry it was a bit fiddley but we used a bit of cardboard (thin stuff that you can easily fold over to the shape required) and put it into the space between the body and chassis. To get the contour of the space we just folded over the cardboard at the edges so when we pulled it out we had a rough shape. Once we had the rough shape we used a pen to draw around it then cut it out. We used that as a template for the aluminium, then stuck that in using high temperature sealant then added the ceramic cloth covering. If you leave the car running in stationary position and put your hand on the bodywork in front of the heat protection it is hot and behind it is very cool so it does work! Here's a photo or two:
| Tunnel (heat protection) | lomondbob | DAX Technical Questions | 11 | 03-10-07 09:08 PM |
| Panel work | Stu J | General Tech Tips & Questions | 6 | 16-09-07 09:10 PM |
| Door Panel | bogster | General Tech Tips & Questions | 5 | 30-11-06 11:10 PM |
| Inner Panel Fitment | Warren | AK Technical Questions | 4 | 26-08-05 08:29 AM |
| GD Dash Panel. | Trigger | General Tech Tips & Questions | 3 | 12-01-04 05:23 PM |
