| Re: Gelcoat Catalyst Have you used any catalyst at all because like you suspect gel is a two part compound. If you are bored and want to pop down I still have some left over from when I was building mine. :thumb: :thumb: HTH
| Re: Gelcoat Catalyst thanks guys - Tinka not used any at all the only reason i need it is her indoors held a door tonight and got it onher feshly painted nails - so i need some - and as luck would have it i sometimes have to go to British Gypsum based in EAST LEAKE - how spooky is that thanks for the offer Tinka and the reply Purple AK regards Ian
__________________ Ian Gascoigne Whether its broken or not fix it |
| Re: Gelcoat Catalyst I definitely remember seeing catalyst in Pilgrim's parts catalogue if that helps at all. John
__________________ Sumo SVA\'d and registered. Paint still to come. www.jgr-design.com/sumo last updated: *27.10.06* |
| Re: Gelcoat Catalyst The people at CFS may be able to help you - loads of stuff to do with fibreglassing. Quick search revealed lots of different type of catalysts. http://www.cfsnet.co.uk/acatalog/index.html Cheers, Malc
__________________ In vino veritas |
| Re: Gelcoat Catalyst Quote:
Yes you should have used a catalyst and the current gel coat that is on the car must be removed and the area cleaned with acetone. Once you have gone this then you can mix up some new resin and catalyst and the correct pigment and this then can be used to repair any damge that you need to. the reason that the orginal gelcoat never went off was that GRP is a thermo-setting plastic and need a catalyst to start the reaction. I have learnt this lesson during my apprentiship and got very sticky and smelly removing the old gelcoat.
__________________ Iain West Midlands Area Rep Dax Owner With A Huddart Engine a smile from ear to ear |
| Re: Gelcoat Catalyst Thanks guys for the tips sort o fworked out that at this time of year it should have gone off by now also worked out from previous threads that i needed acetone to remove the old stuff - i'll get the old off first and then start again - but never mind onwards and upwards Ian
| Gelcoat polishing | Stu J | General Tech Tips & Questions | 4 | 19-10-07 11:59 AM |
| Polishers for Gelcoat | richardd | General Tech Tips & Questions | 10 | 09-06-04 09:38 PM |
| gelcoat reapirs | perky | Pilgrim Sumo Technical Questions | 2 | 31-05-04 07:02 PM |
| Gelcoat - scratches | perky | Pilgrim Sumo Technical Questions | 10 | 30-10-03 01:57 PM |
| Gel coat/Catalyst ratio ? | beanpole | Pilgrim Sumo Technical Questions | 4 | 26-10-03 08:25 PM |
