Old 21-11-06, 05:01 PM
rv8 fuel pump
hi everyone,me again looking for help.my next job on the sumo chassis is to fit fuel tank,pump,filter fuel pie etc.could i ask advice on following.going to fit standard rover v8-sd1 v.d.p 1985 engine.assuming that 8mm fuel pipe will be o.k.im thinking facet pump,but what model should it be only knowing that h,power is 150-155,and pump pressure in manual says 6p.s.i.also is there need for return to tank pipe.has anyone done the same,any infor much appreciated.rico
Old 21-11-06, 05:08 PM
Re: rv8 fuel pump
Facet wil be fine, but they do 'tick'.
I used the one for fast road use - call Merlin Motorsport, they'll sort you out.
For RV8, you dont ened a return pipe to the tank.
Kevin
Old 21-11-06, 05:16 PM
kev kev is offline
Re: rv8 fuel pump
isn't the VdP engine efi?
Kev
Old 21-11-06, 05:31 PM
Miket's Avatar
Fully Paid Up Grandad
Re: rv8 fuel pump
If it isn't EFi, you don't what a Facet, they are to loud, you want a Carter 72 GPH free flow 4-6 psi or they do a 100 GPH 6-8 psi and they are cheaper than Facet.
Both available from Real Steel. :thumb:
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 21-11-06, 05:34 PM
chedz's Avatar
Re: rv8 fuel pump
not sure how load a facet is, but my Carter sounds like a lawnmower, its mounted on rubber bobbins in an attempt to quieten it down, it's just lucky we run very loud engines or the noise would be quite annoying.
Graham
Old 21-11-06, 05:37 PM
Miket's Avatar
Re: rv8 fuel pump
The mistake that a lot of builders make is to mount them in the boot, why not do as I did and mount it on the the chassis adjacent to the gearbox. :thumb:
AK 427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 21-11-06, 07:01 PM
tonym's Avatar
In need of a curry
Re: rv8 fuel pump
Just a thought, i'd advise to fit a second "return" fuel line now while you can, that way if you ever decide to go efi in the future then the line is already there, if not then at worse you've lost a few feet of piping hth :thumb:
BIG TONE
Gallery
Old 04-12-06, 02:03 PM
Re: rv8 fuel pump
I have an RV8 in my Half built sumo. I was advised to fit a silver top facet pump. I think it was £65 or so, you can find them on Ebay. This should delivery 4-6 psi to the engine, but will be a little low on full throttle.
You can fit a red top facet pump that can deliver over 6 psi but you will need a regulator too, as too much pressure will flood the engine. It really depends on the trim of your engine and how your gonna drive the car. If you have a big carb, race cam and drive everywhere with your hair on fire then a red top pump with a regulator will be needed. Standard engine with lesiurely drives through the countryside and a silver top should be ok.
Of course this is only my opinion and no responsibilty can be taken for being wrong .
Old 04-12-06, 05:34 PM
Re: rv8 fuel pump
You can fit a red top facet pump that can deliver over 6 psi but you will need a regulator too, as too much pressure will flood the engine. It really depends on the trim of your engine and how your gonna drive the car. If you have a big carb, race cam and drive everywhere with your hair on fire then a red top pump with a regulator will be needed. Standard engine with leisurely drives through the countryside and a silver top should be OK.
Of course this is only my opinion and no responsibility can be taken for being wrong .
Or just fit a carter = correct pressure and supply so no leaning out of fuel on full throttle or pressure regulator required. :thumb: :thumb: :drive:
Old 05-12-06, 07:29 PM
Re: rv8 fuel pump
Don't forget the check flow rate too, this is just as important as pressure and the two things are not the same.
fuel pump lordy Pilgrim Sumo Technical Questions 13 12-08-05 12:06 PM
Fuel Injection fuel pump problem. Poohbear Engine Tech Tips & Questions 20 11-05-04 11:53 AM
EFi Fuel Pump SWP952 General Tech Tips & Questions 14 25-03-04 03:09 PM
Fuel pump Shaney23 General Tech Tips & Questions 4 30-12-03 07:03 PM
Fuel Pump Miket General Tech Tips & Questions 14 17-12-01 08:05 PM
