| Re: Brake discs The rears shouldn't need the additional cooling provided by the vented discs - solids will be just fine. If there is any other reason you are thinking about this then a measure of the calliper travel and max gap between pads is probably the easiest way to establish viability. You may also find that the disc centreline is different on the vented. I think the vented disc is c.24mm thick and solid c.10mm.
| Re: Brake discs Hi Not needed, your Sumo will be half the weight of the granada and I am sure it stopped OK. jeff
__________________ Jeff My next one will be 2 bolt no 4 bolt no hang on 2 bolt anyway it will have big buck bangs, ohh just remembered it will need heat sensors all over it, Straight up no BS true as I am riding this bike |
| Re: Brake discs Hi Malc, I'm going throughy the same exercise at the moment. Are your hubs 4 or 5 stud? Harry |
| Re: Brake discs Thanks for the replies everybody. I've got 5 stud front and back. Its just that I've seen several websites with grooved/slotted rear discs and was wondering if I really needed to go that way or are solid discs sufficient. I plan to fit a RV8 3.5 l giving @220bhp. Anyone used Brakes international on the internet? Cheers, Malc
__________________ In vino veritas |
| Re: Brake discs I'm using a Granada as my donor and I'm more than happy that if the brakes can stop over a ton of Ford they'll cope just fine with my Sumo. It's my understanding that if you over brake the rear wheels it will fail the SVA as rears will lock before fronts - you'll then have to fit a compensator/adjuster to reduce the pressure. A lot of money spent for no reason IMHO. Darren. |
| Re: Brake discs i go with the rest - vented front and solid rears for my Granada rolling gear and RV3.5 - when i tested (oops) on the lane recently (please be careful with this) stopped an absolute treat until er indoors caught us and sent my mate home and me to bed early with no tea - the will be fine Ian:thumb:
__________________ Ian Gascoigne Whether its broken or not fix it |
| Re: Brake discs Do you mean vented then? There is a difference between vented (like two discs joined together with a gap between them) and grooved discs (i.e. standard solid discs with grooves routed out on the surface).
__________________ See the build in action: http://www.sumobuild.co.uk [Now with added web 2.0 goodness!] |
| Re: Brake discs Quote:
| Re: Brake discs And............his Sumo weighs more than yours, or at least it does with him in it.
| Drilling/grooving brake discs | Robin427 | General Tech Tips & Questions | 13 | 30-03-09 03:55 PM |
| Discs........... | h8jse | General Cobra Discussion | 5 | 02-01-06 09:37 PM |
| Brake discs | CycleSi | General Cobra Discussion | 2 | 10-11-05 03:10 PM |
| Which brake discs? | Andy302 | General Tech Tips & Questions | 7 | 09-05-04 01:52 PM |
| 2nd attempt Brake at which brake discs!! | Andy302 | General Cobra Discussion | 1 | 08-05-04 07:31 PM |
