Old 03-07-07, 09:37 PM
Can't remove my inlet manifold/gasket - sealant too strong
My engine running perfectly - except I have steam coming out of the right exhaust.
Diagnosis: I guess either a mis-seated inlet manifold gasket or blown head gasket.
Current problem: I am really struggling to remove the inlet manaifold and gasket because the sealant I used is too strong. I used it both sides of the gasket and nothing will budge.
Does anyone have any idea how I can remove the sealant?
Also, am I on the right track with my diagnosis or could it be something else - the engine sounds excellent!
Thanks Eddie
Old 04-07-07, 11:19 PM
alfiebeard's Avatar
Location: Annan Dumfriesshire and work in Carlisle Cumbria
removing inlet manifold
Hi I had the same problem I bet you used blue hylomar?,my manifold would,nt budge so I bought a tin of Loctite gasket remover (its in a spray can),
I just feed a rope through under the manifold so you have something to pull on and scratch around the edges of the manifold, then spray the gasket remover right round the flange edges and wait about 10 mins, then give it a tug if it does,nt move repeat the process, i will guarantee it will suddenly lift of and the gasket cement will have desolved its brilliant stuff.
With the steam problem are you losing water? .
hope this helps.
Alfie B
Blue Sumo Mk111 RPI 4ltr crossbolt V8 Piper cam Webber 4 barrel freeflow headers Mallory dizzy Jag running gear with powerlock Diff.
Old 05-07-07, 09:37 AM
dingocooke's Avatar
Are you absolutely sure your not just seeing condensation? I dont know if its your first run up, but if so, run it until its fully warmed the whole block (not just the water) ie for 20 minutes minimum. dont rip it apart until youve done that!!
Steve
We're here for a good time...
Old 05-07-07, 01:06 PM
Marc's Avatar
Hello
I used HYLOMAR. Great Stuff!!
The only problem is, that the to much applied sealant will end up in your oil pan looking like litle wurms. The problem is that i wont dissolve in the oil. Eventualy it blockes the suction filter on your oil pump.
Happend to me.
Symtoms:
-low oil-pressure
-hot oil
-decrease in HP
-nocking noise
Unfortunately for my engine it was to late. The crank needs a regrind.
Marc
Dax Tojeiro fully galvanised chassis!
Painted in Ferrari Tour de France blue
1975 SBC 350 / Tremec T5
On The Road. Yupee!
http://www.cobraclub.com/gallery/sho...00&ppuser=1245
Old 05-07-07, 08:31 PM
Thanks Alfie.
I which I had used hylomar! Instead I used an automotive polyurethane sealant that 'cures'. It has cured alright - rock hard.
I will try the loctite remover if I can hold of some. I have taken the day off work tomorrow to 'attack' the problem.
Thanks dingocooke.
Some loss of water. Had considered the condensation possibility but methinks it would have affected both sides equally and also I have had it running more than once for long periods and still steaming.
Eddie
Old 05-07-07, 11:41 PM
alfiebeard's Avatar
No probs Eddie,
hope it goes ok for you. apparently cured polyurethane can be softened by using any of the following:- XYLOL TOLUENE OR METHYL ETHYL OR TRICHTOROETHENE. and believe it or not plain old petrol can soften it,
so unless you are a chemist I would try the Loctite Gasket remover but if you cant get any try petrol its worth a shot
Alfie B
Old 06-07-07, 08:28 AM
Veteran polisher.
Did you use sealant on all the ports or only the water jacket ones.
I have always used the black type inlet manifold gasket and only ever applied a small amount of silicone around the water ways.
Never had one leak,
Polishes to date = 17
Old 08-07-07, 09:41 PM
Finally met with success and removed my manifold having hooked it up to a fencing winch!
Now struggling eith the cylinder head bolts that are very tight.
Old 08-07-07, 09:46 PM
Club Sec/Rep Liason
Originally Posted by alfiebeard
No probs Eddie,
hope it goes ok for you. apparently cured polyurethane can be softened by using the following:- XYLOL TOLUENE
Alfie B
Is that not Brake Cleaner??
AK 427 351C T5wc
Old 08-07-07, 10:25 PM
Originally Posted by Purple AK
No probs Eddie,
Alfie B
Try carb cleaner, that stuff dissolves most anything. I've actually never used it on carbs to be honest but it cleans injection systems like a good'un.
Tony
Inlet Manifold Sealant Dave Williams Engine Tech Tips & Questions 5 24-09-06 10:45 AM
inlet manifold gasket viperjim Engine Tech Tips & Questions 5 12-06-06 04:20 PM
Head gasket sealant Sidecarbod General Tech Tips & Questions 2 09-05-06 01:56 PM
RV8 inlet gasket sealing? jools General Cobra Discussion 4 26-10-05 12:25 AM
Inlet Manifold NIGELGD General Tech Tips & Questions 16 25-10-04 09:59 PM
