| Brass Craft Filler Base and Cap Hi all. Has anyone fitted a Brass Craft filler to a pilgrim. The neck of the cap is 56mm under the flange but I only have 35mm above the neck on the tank ? I can't cut the cap and am reluctant to reduce the hieght of the neck on the tank to the width of a jubilee clip....... |
| Hi, I had the same problem. http://cobraclub.specialistcommuniti...ft+filler+neck In the end I cut off the smaller bit and a friend of a friend with a lathe reduced the size of the fat bit at the top to the same size as the neck at the top of the tank. It's ali so it machined very easily. You might want to call Chris at Brasscraft, he may have an easier solution but he should also know he's supplying bits that don't fit. I think StuJ has managed to get it on using another technique. I'm sure he'll be along shortly. cheers Graham Last edited by chedz; 14-10-07 at 08:32 PM. Reason: Removed reference to hedgehog prickle injury. |
| Ok, cheers all. I cut the cap yesterday afternoon, gonna fit it tonight. Word of advise to future builders that might see this, if you're building a Sumo and intend using one of these superior (SVA) fuel caps, ask the guys at Pilgrim if they'll fit a 2.25 inch filler neck on your tank when you order it. This should mean that the two diameters that foul sit inside each other and you can use the wider (common) diameters and a 57mm ID fuel pipe with no need for the hacksaw. |
| what ,ask pilgrim to do somthing, your joking, order somthing on monday, which is in stock, say they will send out right away, ha ha, another weekend doing shit. |
| we have nothing, if not hope ! |
| hi , your right, i hope? and i have nothing, yet another,plus another, wasted weekend. thank god scotland are going to win. at least i will know why my head hurts, yahoo, |
| what bits are you after ? my carpets sets will be ready next week, for the last two months..... |
| Brass Monkey Run. | dinosoar | East Anglia | 1 | 31-12-06 09:14 PM |
| Brass Stock | JonnyT | General Tech Tips & Questions | 4 | 11-04-06 10:27 AM |
| Car Craft Show | BenBaron | General Cobra Discussion | 30 | 09-03-04 11:59 PM |
| brass crafts web | MARTIN123 | General Cobra Discussion | 1 | 24-05-03 10:58 AM |
| Knowledge Base | robert | General Cobra Discussion | 11 | 20-12-01 01:00 PM |
