Old 27-03-08, 01:01 PM
Exhaust help
I am now ready to mount exhaust but do not have body, could do with some distances from chassis rail to closest side of exhaust pipe and bottom edge of exhaust to height of chassis rail , if poss anyone in my area ( stafford ) i could measure , greatful for any help , cheers
Old 27-03-08, 01:42 PM
I'll have a look tonight for ya.
I'm in Worcestershire, if you can't get anyone more local you're welcome to drive down.
Old 27-03-08, 03:53 PM
DONT DO IT WITHOUT BODY! All distances are established when fitting body
Old 27-03-08, 07:08 PM
pelham939 is, of course, correct. To obtain the best fit, you will to wait for your shell.
However, to give you ahead start.....
The bottom of my side pipes are just about flush with the bottom of the chassis rails, maybe 0 - 5mm lower.
And the centre line of the pipe (which are 3" diameter), are 5-5.5inches away from the chassis rail.
How close you can get the pipe to the side of the car is driven by how large the hole in the shell is vs the diameter and radius of the bend.
Old 28-03-08, 09:22 AM
cperry , Measurements are great thanks , these are for trial fitting as pelham 939 says wil wait for body to tweak fitting but want to get all running before getting body. Is it also possible to give dimension from front firewall to the 90 bend coming through body.
Old 28-03-08, 03:04 PM
Mine's quite close, only about 30mm away from the firewall, difficult to measure as this is where is pipe diameter changes.
You'll need to get it as close as this so that you are cutting a hole out on a flat piece of shell, as opposed to the moulded edge of the wheel arch.
Make sure you clip any wires well out of harms way too or Mr SVA won't be happy.
Exhaust 427sc General Cobra Discussion 7 09-01-06 10:34 AM
Red Hot Exhaust Andy S General Tech Tips & Questions 7 19-01-05 04:26 PM
red exhaust mikeb General Tech Tips & Questions 7 02-07-04 10:16 AM
RV8 Exhaust Phil McCann Pilgrim Sumo Technical Questions 3 02-04-04 06:44 AM
Dax Exhaust tom DAX Technical Questions 2 25-10-03 06:03 PM
