Just to add what I have done with my top steering column mount.
I had two plates welded either side of the Pilgrim Z bracket as mentioned above this really does stiffen things up.It stops the Z stretching or compressing. However, the chassis plate is fairly thin where is Z mount bolts, so as someone else suggested I used a piece of 3/16" thick plate about 12" long by 2" on top of the chassis. On a visit to Pilgrim I noticed they were adding this spreader plate to a fatory built car. This really makes the whole of the top column mount solid and I can give a really good heave on the steering wheel without the column moving up/down, left/right or forward /aft. It moved a lot before doing these mods. Try these ideas and I am sure you will be happy with the result. Do not bolt the collapsable section or as mentioned before you could become a human kebab, and the collapsable section in the steering column is an SVA requirement. Happy building Ian |
| Dax steering column | MarkyC | DAX Technical Questions | 3 | 31-12-07 06:00 PM |
| steering column | JonnyT | DAX Technical Questions | 4 | 14-08-07 06:02 PM |
| Steering Column | lazyboy | Viper Tech Forum | 16 | 01-05-06 07:50 AM |
| Steering column | drimman | General Cobra Discussion | 0 | 11-07-05 06:51 PM |
| Steering column for Gd | Kelvin | General Tech Tips & Questions | 8 | 06-12-02 11:55 AM |
